Author Topic: glass  (Read 2302 times)
Offline serafumi
glass
« on: 30 November 2010, 11:25 »
hi all , i have just brought 4 doors for my golf gti , my question is the glass in my gti looks like a green tint!! however the glass in the new doors says tinted on them but they look a different colour ? did vw do different tints? also if i have to change them is the 1/4 glass from rear doors easy to take out?
cheers again
tony
Re: glass
« Reply #1 on: 30 November 2010, 11:33 »
you could get brown tint on the mk1, not 100% sure but i think mk2 got it as well? also blue tint is available but pretty rare
Offline serafumi
Re: glass
« Reply #2 on: 30 November 2010, 11:36 »
intresting cause they look kinda brown , do you know if u can get the 1/4 glass outta rear doors? cause if i change glass dont want odd ones
cheers again
Re: glass
« Reply #3 on: 30 November 2010, 11:38 »
you need to remove the main window glass 1st, then undo the bolts holding the rear metal glass guide strip in. to get the main glass out you need to remove the inner and outer slot seals and metal strips, even then its a bit of a struggle!
might be able to drop it inside the door, then undo the bolts holding on the window guides and wiggle glass about till it comes out the guides. then you should be able to pull the rear guide forward enough to get the quarter glass out
« Last Edit: 30 November 2010, 11:40 by rubjonny »
Offline serafumi
Re: glass
« Reply #4 on: 30 November 2010, 11:44 »
ok cool i will give that a go, one other thing while im on the asking questions, the doors also came with electric mirrors, switch and a little bit of loom that plugged into fuse box, however the loom was only out of the drivers door! should i of got a loom from passenger door too?
Offline lewis1641
  • stuck in the 90's
Re: glass
« Reply #5 on: 30 November 2010, 11:56 »
Don't do the rear quarter glass if you are in a hurry- it's a complete pain in the arse!
To get the new glass into the seal it's loads easier if you put the seal in some warm water first.
Good luck.
Offline serafumi
Re: glass
« Reply #6 on: 30 November 2010, 11:58 »
thanks mate not looking forward to that now , i will wait till spring ii guess so its a tad warmer
Re: glass
« Reply #7 on: 30 November 2010, 12:08 »
you will need some loom for the passenger door too ideally, is the passenger mirror electric at least?  if so you could make your own loom with some spades pushed onto the passenger mirror plugs for the short term. corrado and passat up to around 96 have the same electric mirror loom as the mk2, so are ideal donors to pinch it all from
Offline serafumi
Re: glass
« Reply #8 on: 30 November 2010, 12:19 »
i would say its electric , the guy i brought doors off just cut wiring , but i just looked and coming out of the rubber bellow is 5 wires together , white, black,brown,blue/black and white/green . should i just get lenghts of wire and join them to the drivers side loom?
Re: glass
« Reply #9 on: 30 November 2010, 12:37 »
this is how they are wired:
green/white goes to the rear screen heater, you may have to splice into the wire as you'll probably find there is no spare connector for it. the black/yellow wire needs an ignition live feed, where it goes depends on what fusebox you have. where is the hazard switch?
