Author Topic: glass  (Read 2303 times)
Offline serafumi
Re: glass
« Reply #10 on: 30 November 2010, 12:49 »
hazard switch is on column . ce2 fuse box i think , but b4 i splice into fuse box i need to make a loom connecting left and right mirror? correct!! i so wish they would of unplugged everythin instead of cutting , also on of the front electric windows is down is there anyway i gan get it to go back up whilst there of the car
Re: glass
« Reply #11 on: 30 November 2010, 12:55 »
unfortunately the mk2 leccy mirror loom goes up under the dash and across, so a right pain to remove unless you take the dash out. would be easier to make your loom off the car aye.  for a ce2 fusebox you'll need to find the D plug, you'll probably have a spare black wire hanging out of it which you can splice to. pin 9 or 11 is the factory spot.
to get the windows up jump the window motor direct from the battery, there will be a 2 pin plug on it put the wires 1 way to get window to go down, and the other way to get it to go up :)
Offline serafumi
Re: glass
« Reply #12 on: 30 November 2010, 13:04 »
rub jonny your a diamond is there anything you dont know
Re: glass
« Reply #13 on: 30 November 2010, 13:09 »
no worries chap!
