Author Topic: mk 4 gti rear brake problem  (Read 2903 times)
Offline mick ov mids
« on: 29 November 2010, 05:03 »
ok the cars been parked up and not used for 3 day's, go to use it, take of the handbrake and go to drive of then feel drag on the rear end and i have no tension in the handbrake cable unless i lift the hand brake right up high, atm its -8 outside so is there a chance the hand break levers where the cable goes onto on the caliper's has frozen? and just a case of realeasing them? any suggestion's highly appreciated.
thanks mick
[img width=500 height=200]http://i836.photobucket.com/albums
Re: mk 4 gti rear brake problem
« Reply #1 on: 29 November 2010, 12:12 »
any idea's any1?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 29 November 2010, 12:36 »
cable sounds frozen i tihnk my mk2 suffered from this yesterday as minus 5 as soon as everything warmed up was fine..
Offline Adam
« Reply #3 on: 29 November 2010, 14:58 »
Pad sticking to the disk or a sticky caliper. Chuck some luke warm water on them.
Down Hill From Here.
« Reply #4 on: 29 November 2010, 16:02 »
all sorted , the handbrake arms was from , unloosend with abit of puruasion and wd40 now it's workin fine, gonna leave the handbrake of and just leave in gear i think untill this miserable weather is over with  :smiley:
thanks for the suggestion's guy's
mick
Offline vwprime
« Reply #5 on: 29 November 2010, 16:19 »
Just dont forget about puting it in gear now  :wink:
can be a bit  :embarassed: as you lornch of the drive or into another car  :laugh: :smiley:
not that i have ever done that you understand  :lipsrsealed:
TRANSFORM, & ROLL OUT!
Offline richandhazel
« Reply #6 on: 29 November 2010, 18:03 »
My handbrake was stuck on this morning. Did the same thing last year in the bad weather. Water gets into the cable sheath and then freezes.
Having defrosted the Golf, Hazel then had to defrost the Polo and take that instead.....not a happy bunny!
By the time I used the car at 1pm it was OK but am leaving it in gear with handbrake off until the weather warms up again.
Offline Steve_PD
« Reply #7 on: 29 November 2010, 19:37 »
what Richard said. happened to mine last year the rubber boots had split letting water in which froze. as a quick fix I put copper slip in the boot which solved the problem.
Had no problems this year as I replaced the cables a few months ago
