Author Topic: BIG problems with lights,needs mk3 expert!!!!!!!  (Read 2218 times)
Offline jiminbmth
  • brings back the sunshine!
« on: 27 November 2010, 15:10 »
 :angry:   hi everyone!!!    bit cheesed off now with my otherwise mint low mileage mk3 cab 2.0 avantgarde!
when i turn on my main quad headlamps(hella),only sidelights work,and then when i turn back to sidelights ,they come on dim as they should.
the main beam works but only if i hold back switch,then they both come on.they wont stay on on their own tho.
i have checked wiring ....ok
i have replaced indicator/highbeam stalk.....ok ,no change.
all fuses ok
any ideas/anyone have similar probs?
jiminbmth ;)
Offline GrandMstRamRod
Re: BIG problems with lights,needs mk3 expert!!!!!!!
« Reply #1 on: 27 November 2010, 15:11 »
have you installed the relay into the fuze box
Offline jiminbmth
« Reply #2 on: 27 November 2010, 15:14 »
errrr?
jiminbmth ;)
« Reply #3 on: 27 November 2010, 15:23 »
when i installed mine i had to bridge a connection by the fuze box made it out of two wire clips and a pice of wire see if i can find the tutorial to install them
« Last Edit: 27 November 2010, 15:35 by GrandMstRamRod »
Offline jiminbmth
« Reply #5 on: 27 November 2010, 16:57 »
thanx legend!!!
way too cold to look at the mo!
jiminbmth ;)
« Reply #6 on: 27 November 2010, 20:38 »
Confused, mine fitted with no wiring mods.
Offline jiminbmth
« Reply #7 on: 27 November 2010, 21:29 »
mine did work tho til recently.....dunno....will try this fix
jiminbmth ;)
« Reply #8 on: 27 November 2010, 23:52 »
Maybe the dim / dip restior (spelling) has burnt out.
Offline jiminbmth
« Reply #9 on: 28 November 2010, 23:04 »
dim/dip resistor? what on the switch?
jiminbmth ;)
