Author Topic: BIG problems with lights,needs mk3 expert!!!!!!!  (Read 2231 times)
Offline crazy_e
Re: BIG problems with lights,needs mk3 expert!!!!!!!
« Reply #10 on: 28 November 2010, 23:13 »
have you got just standard quad bulbs in there or are they HID's?
Offline dom
  • Back in a Mk4
« Reply #11 on: 29 November 2010, 08:33 »
dim/dip resistor? what on the switch?
I may be wrong but the dim/dip resistor can be found underneath the airbox, there should be a bright yellow plug!
« Reply #12 on: 29 November 2010, 10:43 »
its the flasher switch most likely, or the wiring to it. all the power from the lights comes via the flasher switch. you know fuses are ok as the lights flash fine, the problem is you have lost power feed to the wiper stalk. it might be relay #18 is loose tho, give it a wiggle.
no relay for the lights as such, but the 18 relay supplies lots of stuff in the car with ignition live, the lights included.
check the white/black wire to the stalks to pin 3 on the plug gets power when the light switch is on the 2nd click. if you dont get power here, you have a damaged wire or the headlight switch is bust. check for power at the white/black wire to the headlight switch, this is at pin 58 on the switch. if you get power here, then light switch is fine, follow the wiring back and check for faults.
« Last Edit: 29 November 2010, 10:46 by rubjonny »
Offline jiminbmth
  • brings back the sunshine!
« Reply #13 on: 29 November 2010, 15:53 »
normal lights yer,not hid .....BIG hanxeveryone....will let u know.......1 week later......!
jiminbmth ;)
Offline jiminbmth
« Reply #14 on: 03 December 2010, 23:29 »
[javascript:void(0);b]ok , got to the root of the problem,it was the actual headlight switch!!!!
thanx everyone for input
[/b]
I feel an ebay session on the cards.....but can I get away with just buying what I looking for ,javascript:void(0);
or do I get sucked in?!javascript:void(0);
jiminbmth ;)
