Author Topic: How important is the centre bore 56.6mm vs 57.1  (Read 5741 times)
Offline Ben Lessani
« on: 27 November 2010, 11:28 »
I'm going to have to put winter wheels on the Mini Golf, as the big wheels will be rubbish in snow. Considering I've got a few spare sets of alloys from the Golf, I was wondering if I could get away with using some of them?
Golf 4x100 57.1
Mini 4x100 56.6
Does that 0.5mm make a big difference, last thing I want is dangerously fitted wheels. But if its okay, then I'll get some winter tyres on my 14" P slots ... and throw them on the Mini!
Re: How important is the centre bore 56.6mm vs 57.1
« Reply #1 on: 27 November 2010, 20:31 »
Yes it makes a difference as the wheel is then only located with the bolts which can lead to vibration prolems.
Offline Ben Lessani
« Reply #2 on: 27 November 2010, 20:49 »
Shucks, looks like all the MK2 bits are for the skip then.
Offline danny_p
« Reply #3 on: 27 November 2010, 21:12 »
cheep plastic spiggot ring fixes it.
once wheel is bolted up tight it takes a LOT to make it move ( like a wheel bending type inpact )
all the VW's have gone bar 1.
Offline Ben Lessani
« Reply #4 on: 28 November 2010, 01:44 »
Doesn't look like a 0.5mm spigot ring exists! http://spigot-rings.com/shop/features.asp
« Reply #5 on: 28 November 2010, 09:32 »
A good machine shop should be able to make some, is the Mini on bolts or studs.
Offline Ben Lessani
« Reply #6 on: 28 November 2010, 12:25 »
Not sure yet, I'm going to be taking a wheel off today to try and find out what make/model they are.
Offline danny_p
« Reply #7 on: 29 November 2010, 01:12 »
ummm 0.5mm
i bet a lot of wheels arn't round to within 0.5mm TBH well after theyve hit a good pothole or two anyway.
a pikey may suggest spinning a few turn of tape onto the hub to assist in locating the wheel.
Offline fishnchipsx2
« Reply #8 on: 30 November 2010, 19:27 »
A couple of layers of paint would probably make up the difference tbh.
Offline massao
