Author Topic: mfa probs  (Read 1371 times)
Offline golf88
mfa probs
« on: 09 February 2005, 20:07 »
hi could u help me my battery went flat on my golf i used 1 of them booster packs but since i used it my computer stopped is there any way to make it work again :sad:
Offline piggy
  • What you lookin' at sonny?
Re: mfa probs
« Reply #1 on: 10 February 2005, 00:59 »
If you've got a healthy battery now, it probably just needs resetting
Best way is to undo your battery overnight then reconnect.
It'll reset the MFA.
Offline Dannyd
  • LOOK AT THAT VALVER GO!
Re: mfa probs
« Reply #2 on: 10 February 2005, 05:53 »
check the fuse under the dash
wacked up on scuby snacks!
Offline gibby
Re: mfa probs
« Reply #3 on: 10 February 2005, 10:20 »
Two ways to fix, either take the terminals off the battery for about a minute or so, or quickest way is to pull out the fuse for the MFA and stick it back in again and it should reset.
......now officially dubless.
Judderi
Re: mfa probs
« Reply #4 on: 10 February 2005, 10:36 »
The fuse trick worked for me when this happened. Its the third one allong from the left. Pull it out for 10 secs then push back in. A quick pull and push does not work!
Offline golf88
Re: mfa probs
« Reply #5 on: 10 February 2005, 18:20 »
thanks everyone 4 gettin in touch will try all the ideas u av sent me cheers all :grin:
