Golf mk2
mfa probs
Topic: mfa probs (Read 1454 times)
golf88
mfa probs
09 February 2005, 20:07 »
hi could u help me my battery went flat on my golf i used 1 of them booster packs but since i used it my computer stopped is there any way to make it work again
piggy
Here all the time
What you lookin' at sonny?
Re: mfa probs
10 February 2005, 00:59 »
If you've got a healthy battery now, it probably just needs resetting
Best way is to undo your battery overnight then reconnect.
It'll reset the MFA.
Dannyd
GTI forum regular
LOOK AT THAT VALVER GO!
Re: mfa probs
10 February 2005, 05:53 »
check the fuse under the dash
wacked up on scuby snacks!
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Re: mfa probs
10 February 2005, 10:20 »
Two ways to fix, either take the terminals off the battery for about a minute or so, or quickest way is to pull out the fuse for the MFA and stick it back in again and it should reset.
......now officially dubless.
Judderi
Guest
Re: mfa probs
10 February 2005, 10:36 »
The fuse trick worked for me when this happened. Its the third one allong from the left. Pull it out for 10 secs then push back in. A quick pull and push does not work!
golf88
Re: mfa probs
10 February 2005, 18:20 »
thanks everyone 4 gettin in touch will try all the ideas u av sent me cheers all
Golf mk2
mfa probs
