Author Topic: The only thing...  (Read 6128 times)
Offline celticdragon
The only thing...
« on: 24 November 2010, 19:51 »
So a couple of months in and the only thing that's niggling me is that the doors need to slammed to close properly...seems to happen for all 4. I spent years telling the kids not to slam and now I have to say to pull harder...even I have to put a bit more effort into closing.....common experince?? I thought give a couple of months to bed in then possibly copper grease up??
Opinions always graciously accepted
MK VI GTI, Manual, 5-dr, Carbon Grey, leather n rear parking....with rear LED lights...n a little Stage 1 Remap ;-)
Offline Snoopy
  • Moderator
  • Geoff.
Re: The only thing...
« Reply #1 on: 24 November 2010, 20:20 »
Is it just the hinge/spring is stiff or that there not shutting properly.
I find the mk6 one of the easiest. Is it a 5 or 3 door as the 3 will have much heavier doors.
It maybe down to air pressure a known thing with all VWs since the beetle.
Try dropping a window alittle bit then shutting the door and see if it shuts easier.
Current Garage:
35+ years of GTI ownership.
Offline Tone2have
  • Gutted - stolen April 10 but now black is back!
« Reply #2 on: 24 November 2010, 20:29 »
Funny, I was just considering posting a topic about the mk6 doors. 2 weeks ago I cleaned the car with one of these spray on, rub off gizmos from the shopping channel. The car looked great but when I pulled off the drive i could hear movement in the rear doors. Took it into VW and they put some moisturizing stuff (apparently £49 a bottle) on the door rubbers and hey presto the noise/apparent door movement has gone. Initially I thought it was the locks as there seemed to be so much movement on the doors
GTI MK6 black, man, 5 dr, 18" Monza shadow, Xenons, RCD510 Dyna Audio, Winter pack, ordered Sept 2009 - Delivered April 2010, stolen next day - gutted
« Reply #3 on: 24 November 2010, 20:51 »
5 door, I think more stiff as they fit fine just need noticable more effort. I'll try the window drop...
Offline am1w
« Reply #4 on: 24 November 2010, 21:00 »
Had all 4 doors re-hung and adjusted. Perfect closing with no effort.
Also, got bonnet re-aligned.
Cars are built by drug fcuked robots and/or workers.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #5 on: 24 November 2010, 21:24 »
There is a latch just up from the bottom hinge that maybe whats stiff. I have sprayed white spray grease on mine as well as the hinges.
« Last Edit: 25 November 2010, 18:08 by Snoopy »
Current Garage:
Offline devito
« Reply #6 on: 24 November 2010, 23:45 »
KRYTOX?
Offline R32UK
« Reply #7 on: 25 November 2010, 09:13 »
KRYTOX?
Not sure about the name but i was given some similar stuff... apparently they use it on the eos as the chassis has alot more flex than the golf which leads to those creaks and squeeks
Offline RedHP
« Reply #8 on: 25 November 2010, 16:10 »
I must be one of the lucky ones, all 4 passenger doors close well and have a nice sound, not a CLUNK !
Mk6 GiT since birth in 2010
YNWA
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #9 on: 25 November 2010, 18:11 »
Dupont Krytok Part No G052172A1
Current Garage:
