Author Topic: Jerking when coming on/off power, clutch inspection & dogbone?  (Read 2935 times)
Offline The Dave
Hi guys. As some of you know since I've had my clutch done in March (Valeo single mass kit from ECP, on a 99 AGU 1.8 20vt MK4) when I come off the power a bit hard, it sort of feels as if the car is jerking back and forth quickly a couple of times for half a second. My mechanic checked my mounts for me, engine and dog bone and checked they're tight etc. Couldn't find an issue. I have a polybushed dog bone mount also. Powerflex bushes...
But, I'm wondering if a new dog bone completely may be worth getting? Mines polybushed but I'm thinking of ways to rule out parts to see what the issue is. I was considering the R32 dog bone as people recommend these for less harshness in terms of vibrations at low RPM but still good shifting.
It's started doing this jerking a bit more pronounced now, like 3 or 4 jerks quickly when coming off the throttle and even going on the throttle hardish. It's rock solid to drive the car smooth with these annoying jerks lol. It's as if the car is rocking back and forth very quickly for half a second. Real weird to describe in words.
Do you think the dog bone (gearbox mount) is worth changing for peace of mind? I will have to get my mechanic to check my engine mounts again for wear/their condition. The engine mounts themselves were new a few yrs ago also!
Lastly is there any way you can inspect the condition of the clutch, flywheel and all that without removing the gearbox?
Thanks for any ideas folks.
Offline richw911
Re: Jerking when coming on/off power, clutch inspection & dogbone?
« Reply #1 on: 23 November 2010, 19:13 »
Worth a try i guess though i doubt it is that  :undecided:
You need someone like topher to drive it it will tell you whats wrong with it  :wink:
Offline The Dave
« Reply #2 on: 23 November 2010, 19:22 »
I'm going to R-Tech sooooon for a TIP, 007p, health check on the rollers aswell etc so hopefully one of those guys can give it a run and give me an idea of whats knackered lol it's just annoying as it drove beautifully with the DMF setup. It's still not that bad now but it's enough to annoy me :D
Offline richw911
« Reply #3 on: 23 November 2010, 19:27 »
Good plan you should try driving another MK4 with a SM fitted also  :wink:
Offline The Dave
« Reply #4 on: 23 November 2010, 19:28 »
If it turns out be the clutch I will rip it out and stick a proper G60/VR6 + bolts combo in lol.
Offline The Dave
« Reply #5 on: 25 November 2010, 01:00 »
Anyone know the part number for the correct R32 dogmount which'd work fine on my 5 speed 99 AGU? Also how much are they if anyone knows?
Cheers :)
Offline Adam
« Reply #6 on: 25 November 2010, 01:45 »
Cheers :)
1 x 1J0 199 851 AM (Mount)
2 x N10268302 (Bolt)
1 x N90597005 (Bolt)
1 x N10246603 (Bolt)
Down Hill From Here.
Offline vwprime
« Reply #7 on: 25 November 2010, 15:50 »
Make shore you put LOTS of WD40 on the bolts that go into the subfram.
When i was doing mine i sheerd both off as thay had corroded thenselfs on to the mount  :rolleyes:. 5 min job took 2h  :undecided:
TRANSFORM, & ROLL OUT!
Offline Luke-P
« Reply #8 on: 25 November 2010, 17:15 »
I have a similar issue to this also. I know, it is quite hard to describe. As if the engine looses all power for a split second then kicks right back in again. Not sure if yours is the same? Well, my MK4 I had before this had a DMF setup and it never did this. Looking through my history and it seems my current Golf has had the DMF replaced with a single when the clutch was done. I'm not really too happy with the drive also.
Hope this helps.
Offline The Dave
« Reply #9 on: 25 November 2010, 20:04 »
Thanks Adam :) Appreciate that.
No power loss issues, although a couple of times it's felt as if the clutch has taken a second to actually engage say changing 2nd to 3rd which is odd, not too often and not if I'm driving hard, just if I am pootling about, only done it a few times since March...
I would prefer have a DMF setup again without a doubt but you have to chance it, it's not THAT bad but having driven it with the DMF it felt nicer before :)
I'm wondering if I want a different car anyway.. I like the Golf but I quite fancy going back to my Vauxhalls, MK4 Astra SRi Turbos are cheaper now.. lol
