Total Members Voted: 43
Voting closed: 17 February 2011, 22:20
With regards to ‘SNAP OVERSTEER’…have you ever experienced it on a VW?
You have completely ignored references to ESP I notice…why don’t you go out and TRY to get a Mk6 to oversteer…if you can, you are a better driver than me.
Second clip. Four winter tyres performs better than four all-season tyres. Then front-only winters is compared to four winter tyres, and again unsurprisingly the four winters does better. There is no test of a set-up of rear-only winters.
Quote from: Ben Lessani on 03 December 2010, 18:12When on earth did I say change the rear wheels only!??!?!Er, lots and lots of times?
I'm not saying you're wrong, I'm saying you are giving out dangerous advice.Less grip over the back wheels = snap oversteer - factLess grip over the front wheels = controllable understeer - factMore grip over the front wheels = better front-end traction - factMore grip over the front wheels = snap oversteer - factBalanced grip over the all wheels = normal handling characteristics - factI'm not advocating changing 2 tyres, I keep saying, change all 4 tyres. BUT IF YOU INSIST on changing only 2 tyres, make it the rear set, so it doesn't cause the above ...
Quote from: DDRFan on 01 December 2010, 21:45i've probably left this a bit late but after 2 days of 'moderate snow' i'm beginning to get a bit more worried about more and more. it's not been too bad in Greater Manchester but today i did have to dig out my driveway to park up. so is the consensus just getting a pair for the front sufficient? No, you have to change the rears first, then the fronts.
Not sure who the above was directed at?But seriously, stop advising people that only fitting front winter's is a safe thing to do, its moronic, ignorant and dangerous - to not just yourself, but other road users.
Quote from: SoVW on 03 December 2010, 18:46It's not a complicated concept. I'll put it in a simple 1,2,3 scenario to make it easier for you to grasp:1. Bob fits two front winter tyres2. Bob loves the extra traction and speeds away, happily overtaking losers with their summer tyres3. Bob panics as child runs out from between parked cars and tries to swerve to avoid, but instead of keeping control spins onto pavement and runs over mother with pram.Or:1. Bob leaves four summer tyres on and either can't get off his drive, gets bus or bikes in or has day off workOr:1. Bob leaves four summer tyres on manages to get off drive but realising he has no grip drives around slowly and scared for his own life / carOr:1. Bob fits four winter tyres2. Bob speeds around3. Bob panics as child runs out but successfully swerves around / brakes with shorter shopping distance and remains on road.OK, maybe that's not made it simple enough for you to grasp but my point is that because of the increased grip you are more likely to drive faster and will be caught out in the event of an emergency manoeuvre, or just going around a corner a bit too fast or not being able to brake in time. You may not be running "illegal" tyres but you could still be responsible for the injury or death of someone or yourself. For the sake of a couple of hundred quid.I don't know who Bob is. My name is not Bob.I'll give you an alternative scenario.1. Roberta fits two front winter tyres.2. Roberta is bloody relieved she isn't sliding all over the bloody road even on the flat, and can actually drive the car in and out of her drive, and up the hill to the main road.3. Roberta gets to work on time every day, without taking time to haul AutoSocks on and off.4. Roberta is very well aware that she still has summer tyres on the rear wheels, and as a result does not drive like a raving lunatic. In particular, she takes corners in snow as if she had four summer tyres, and always makes sure she has plenty stopping distance to avoid sudden braking.5. Roberta sees child on pavement, slows down, and is able to brake in good order when required.Roberta Rolfe.
Quote from: Rolfe on 03 December 2010, 20:19Second clip. Four winter tyres performs better than four all-season tyres. Then front-only winters is compared to four winter tyres, and again unsurprisingly the four winters does better. There is no test of a set-up of rear-only winters. Erm ... yes there was, seriously, watch it againhttp://www.youtube.com/watch?v=8cBSWEhimdAhttp://www.youtube.com/watch?v=EdtAm7RsTmE
When on earth did I say change the rear wheels only!??!?!Oh my god, its like talking to a moron. I quite literally quoted myself every time I mentioned rear tyres and NOT ONCE did I ever advocate fitting winter tyres to just only the rear - every single time, I said, FIT ALL 4.
I keep saying, [....] IF YOU INSIST on changing only 2 tyres, make it the rear set ...
