Author Topic: Rear Wiper Help?? Sorry Guys :(  (Read 1006 times)
Offline lowry_uk
« on: 17 November 2010, 16:46 »
Hi guys
I have recently bought my MK4 golf TDi 150 and now the rear wiper isnt working.  Any suggestions to check
Thanks in advance. I have tried the searches etc and its quite a common fault but not found a know/common fix
Golf MK4 PD130
18" Cades Tyrus Alloys after a Swap for some 3SDM's
Offline Rhyso
Re: Rear Wiper Help?? Sorry Guys :(
« Reply #1 on: 17 November 2010, 16:47 »
Most likely the rear wiper has leaked and caused the motor to rust
Replacement wiper motor is probably the fix you'll need
Offline lowry_uk
« Reply #2 on: 17 November 2010, 16:57 »
wow! thanks for the rapid response.  Cheers
Are they easy to fit, have i seen an how to for this.......... sure i have
Golf MK4 PD130
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 17 November 2010, 17:02 »
Have a look in maintenance section there's one in there..
Offline richw911
Offline Tazzy
« Reply #5 on: 17 November 2010, 21:46 »
just to add...
(i was thinking about making a new post, but as this is here...)
the rear wiper blade, ive only had the car a few months and already ive gone through 3 rear wiper blades, whats wrong with them? ive never had this problem before
If It Comes Off, Modify It!
Offline richw911
« Reply #6 on: 17 November 2010, 21:47 »
just to add...
Cheap ones?
Offline james2
  • No scammers please.
« Reply #7 on: 17 November 2010, 23:36 »
Just remove the motor , throw it away , put a rubber bung in the hole in the glass ,job done .....save a bit of weight and the hastle of it breaking again  :wink:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
