Author Topic: Engine fault light + New accelerator = £240 :O Shocking!  (Read 1697 times)
Offline jonnyb
Exactly what it says as the title, just had the glow plug/engine fault light flashing, so i took the car to mr VW.  After the initial shock of £108 inspection fee, which on its own is a rip off, i was then told that the accelerator was losing the will to live and needed replacing.  Well in total the cost is £240.  I cant help but think i wish id bought the Vagcom gear and done it myself.  How hard can replacing a pedal be!
Anyone else think this is a bit steep?
Offline AlanD
  • MK5 2.0T 16v
Re: Engine fault light + New accelerator = £240 :O Shocking!
« Reply #1 on: 16 November 2010, 11:55 »
This is just one of the many reason why my car will never see a VW garage. Find yourself a nice friendly local VAG specialist garage and use them from now on.
Try asking in general VW section for people who live in Oxford and who they use.
Offline jonnyb
« Reply #2 on: 16 November 2010, 12:17 »
Hi, thanks for the reply.  I knew as soon as i dropped the keys off that i was being a fool.  However with me needed to get to work, and the VW garage being 20m down the road, i just dropped it off without thinking.
Next time i think i will do it myself.  Plus id like the challenge.
As a side note, which Vagcom cable do you need for the mkv?  As i couldve used that to pin point the problem (i suspect).
Offline Rhyso
« Reply #3 on: 16 November 2010, 12:43 »
You need either the MicroCan or HEX-USB Can lead.  The latter can do all VW's with a diagnostic port, the former just those that are CANBUS based only i.e MK5 onwards  :nerd:
Isn't it all built into the pedal itself?  :undecided: A new pedal is approx £80 and a 10 minute job to replace  :sad:
I'd kick up a fuss and see what you can get off the bill
Offline jonnyb
« Reply #4 on: 16 November 2010, 13:17 »
The replacement is only £80  :sick:
Well and truely a$$ raped it would seem.  Is it realistic to get them to budge on the price?  Id be suprised if they threw in a free tree air freshener.
Offline mortygt140
« Reply #5 on: 24 November 2010, 01:39 »
Sorry but a set of spanking new golf gti ally pedals including the new accelerator pedal is only around £100 and has the instructioninside on how to change them so how can they charge you over £200 for a standard rubber pedal????? Id be contacting vw customer services!!
Darren
