Golf mk2
SH&T Fog lights,
Topic: SH&T Fog lights, (Read 2464 times)
beechymonza
mad beech
SH&T Fog lights,
13 November 2010, 17:40 »
Ok just wired my front fog lights up, Found original plug under header tank as they were wired 2 a stupid button by leccie window buttons,
Just tried them in the dark an they dim the main beam and the whole set up gives less light out than just having main beam on its own,
No guts No glory,
clipperjay
Re: SH&T Fog lights,
13 November 2010, 17:56 »
So did you test what voltages came off the plug? Maybe its time to just rewire some relays and find a signal wire to the fogs and get actual 12V through them?
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
beechymonza
mad beech
13 November 2010, 18:05 »
I used to have them on the relay system, Because my car is a 1988 model, I added big bumpers ,
So i found the fog light plug an wired it through that 2day,
So i suppose i could use that plug as the switch and go back 2 the relays,
No guts No glory,
clipperjay
13 November 2010, 18:23 »
Yeah you know the better cable and higher voltages is the only way to get decent lights fella!
beechymonza
mad beech
13 November 2010, 18:27 »
I was totally dissapointed after waiting all day for it 2 get dark
I was like a kid waitin 4 santa 2 come
No guts No glory,
clipperjay
13 November 2010, 18:30 »
Its a sad fact 9V was bling back then like flares just in todays driving conditions you are better off re wiring the loom to decent relays instead of the fuse box! I had to put Audi TT zenons into my Rallye for the exact same reasons and I love OEM, but like my life more
cняis
Know there's something burning over there...
Reply #6 on:
14 November 2010, 00:57 »
so its normal for the light looms to get just 9v then? my H4 plugs were getting 9v but i thought it was unsually low
Quote from: oilman on 19 November 2010, 14:24
clipperjay
Reply #7 on:
14 November 2010, 15:53 »
Well yeah "but not as we know it Jim"
Most bulbs are rated 12V-55w-60w and would love to see at least 11V for brighteness.... The loom and relay on the fuse box
(10amps)
just can't produce the juice! If the bulbs say 9V then thats what its rated i.e side lights, because I don't want to see light housings being melted
cняis
Reply #8 on:
14 November 2010, 18:59 »
but with the engine running the new H4 plugs on my new loom receive just over 12v
clipperjay
Reply #9 on:
14 November 2010, 19:18 »
New loom and plugs
Golf mk2
SH&T Fog lights,
