Author Topic: Top mounts?  (Read 1550 times)
Offline Rysm
Top mounts?
« on: 09 November 2010, 22:25 »
Newbie question...
Failed MOT on Monday due to 'rear offside shock insecure'. I checked it out and it appears that the rubber bush which sits between the top of the strut and the underside of the wheel arch is missing (possible error by previous owner while fitting coilovers). Is this the part that is referred to as the top mount?
There is another rubber bush which sits in a dish on top of the wheel arch, which can be seen from in the boot... I'm not talking about this rubber mount... I'm talking specifically about the one which sits on top of the strut and pushes up in to the underside of the wheel arch.
I need to source a new part obviously, but wanted to check that I'm searching for the correct part first.
FK Automotive coilovers have been fitted, in case that changes anything.
Re: Top mounts?
« Reply #1 on: 10 November 2010, 08:51 »
this any help, sounds like parts 13 is the one thats missing? might as well do 14 as well as they come in a kit usually:
can get new rubber bits here:
http://www.vwspares.co.uk/g2suspension_rear.php
Offline Benrevs
Re: Top mounts?
« Reply #2 on: 10 November 2010, 14:06 »
Also double check that it isnt stuck up the top of the wheel arch/mount.
Offline Rysm
Re: Top mounts?
« Reply #3 on: 10 November 2010, 19:29 »
Yep, found that diagram late last night and ordered the kit from vwspares.
I didn't check that the mount was still stuck up in the wheel arch. I hope it isn't as it will spoil the theory that the missing mount is the cause of the insecure shock.
Re: Top mounts?
« Reply #4 on: 11 November 2010, 10:03 »
if you have coilovers this probably wont be the casue, on the oem shocjks there is a small circlip which basically holds all the top of the shocks up. there is a washer that sits on that, then the metal plate. if the circlip goes or the metal plate it'll all collapse into the boot.  coilovers are a different design so this doesnt usually happen :)
Offline Rysm
Re: Top mounts?
« Reply #5 on: 11 November 2010, 20:32 »
The mounts arrived today (kudos vwspares). It took 20 mins to replace all 4 and it fixed the insecure shock problem.
This is how all vehicle repairs should be.  :smiley:
