Author Topic: mk2 dash speakers  (Read 4425 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
mk2 dash speakers
« on: 06 February 2005, 19:30 »
any1 know where i can get those tiny speakers that are in the top of the dash
i want better ones as when i turn sound up they crackle
and i have got new door speakers and not got round to rear speakers yet
so sound is just in the front
Offline bunter
Re: mk2 dash speakers
« Reply #1 on: 06 February 2005, 22:36 »
I just bought a set of components for my MK2 and put the tweeters ion the top of the dash with custom mountings.  :cool:
Offline VR6_ROB
« Reply #2 on: 06 February 2005, 22:40 »
where from I am after some
Offline bunter
« Reply #3 on: 06 February 2005, 22:58 »
what the speakers or moutings?
Offline VR6_ROB
« Reply #4 on: 07 February 2005, 21:00 »
speakers
Offline VR6_ROB
« Reply #5 on: 07 February 2005, 21:01 »
both
Offline bunter
« Reply #6 on: 08 February 2005, 08:54 »
I bought my speakers from ICE Direct in Peterborough, they are 6.5" so i bought some audioscape door pods to house them then i just made up some mountings for the tweeters which i put in the dash. i did this by removing the old dash speaker, turning it upside down and drawing round to get the perfect fit. I cut the mounts from 5mm MDF and they were a great fit and the grilles went back on over the top no problem. hope this helps
bunter.
Offline Dizzie
  • Make friends with your fast
« Reply #7 on: 08 February 2005, 14:57 »
you can fit a tiny 3 1/2" speaker in the dash, but it's pointless when you can put a tweeter from a component set in there and have a lot better sound overall. forget rear speakers. how often do you sit back there :wink:
Sub off amp and 13/17cm's off the headunit sound really good.
Mk4 Golf 150PD
Offline bunter
« Reply #8 on: 08 February 2005, 15:10 »
id personally run eveything off amps as the HU internal amp is very weak, just make sure you dont scrimp on cables!!!
Offline Dizzie
« Reply #9 on: 08 February 2005, 15:17 »
well yeah if you can afford it. I plan to use my ST100 to run the front speakers and get a larger probably dual mono amp to run a better 10" in a proper enclosure one day.
Mk4 Golf 150PD
