Author Topic: Hids on Mk6 do fit? ***Yes They Do!  (Read 11220 times)
Offline KennyGTI
« on: 09 November 2010, 18:53 »
Ordered a set of 5000k hids from hids4u. Had a look about some other mk6 golf forums (slag) today and found you can fit them after all! Headlights need removed to do so is the only downside so back off with the front bumper! Just posted this to let others know it can be done somehow so will let you know how it get on.
« Last Edit: 19 November 2010, 19:21 by KennyGTI »
APR Stage 2+
Offline RunRabbit
Re: Hids on Mk6 do fit?
« Reply #1 on: 09 November 2010, 18:56 »
You're fitting xenon lights into a halogen headlight?  :undecided:
Expect to get flashed by a lot of people when the light scatters all over the place. PC plod might have something to say too.
Offline am1w
« Reply #2 on: 09 November 2010, 18:57 »
No Bi-Xenons? :sad:
Why? :huh:
Offline brendan
« Reply #3 on: 09 November 2010, 19:01 »
Nearly as annoying as people who drive with their fog lights on.
2009 Ford Focus ST2 - 288bhp, 390lb/ft
« Reply #4 on: 09 November 2010, 23:47 »
Mot laws are changing next year and they will now fail.
Offline KennyGTI
« Reply #5 on: 10 November 2010, 08:28 »
Asker - The Bi Xenons were working out to be too dear, getting to the stage I can't justify spending that much on lights when it could be spent elsewhere i.e. the house. This opition will keep me satisfied and at a 1/10th of the price.
It is H7R bulbs I have got, designed for reflector housing, same as Civic GT's and Renault Lagunas etc. Dont worry I wont be blinding people, ran this set up on my Polo for 2 and a half years without any problems, people flashing or failing MOT. Went for the 5000K to keep it away from naff looking cheap HIDs that people fit and look OEM as possible!
APR Stage 2+
Offline MAW73
  • Used to like Golfs :-)
« Reply #6 on: 10 November 2010, 08:49 »
Sounds good Kenny..... Be nice if you can get some before and after shots.
2014 BMW F20 M135i, Auto
Offline KennyGTI
« Reply #7 on: 10 November 2010, 08:54 »
Will do Martin,
Hopefully get it done om Friday if I can get it off.  :cool:
APR Stage 2+
Offline MAW73
« Reply #8 on: 10 November 2010, 09:10 »
Will do Martin,
Top man.... good luck with it  :smiley:
« Reply #9 on: 10 November 2010, 10:00 »
http://wrecks2riches.co.uk/2010/10/2011-changes-to-mot/
HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers.
