Author Topic: Mk4 rear speakers 3door  (Read 2022 times)
Offline MickeyC
  • Mk4 GTI 1.8T
« on: 07 November 2010, 11:07 »
How do you remove the rear card from a 3dr mk4 to change the speakers?
also are the speakers the same size as the front?
i upgraded my fronts to JBL components so need to change the rears.
should i stick with the same speakers or can you recommend different speakers for the back, if it makes a difference?
And i suppose ill need the same Autoleads adapters?
Thanks in advance.
« Last Edit: 07 November 2010, 18:02 by MickeyC »
Offline james@bloomz.co.uk
Re: Mk4 rear speakers 3door
« Reply #1 on: 07 November 2010, 17:46 »
03 on golf? is a mk5 is that right?
So 99 thru to 03 its the same front and rear,    SAK-3103
Getting the door card off is straight forward if you have the tools.
You need some good quality plastic trim tools to help with opening the handle grip and popping the clips around the edges,     also a torx set to get the screws along the bottom edge  ;-?
James
