Author Topic: electric heated wing mirror  (Read 1659 times)
Offline palmer
« on: 06 November 2010, 21:01 »
hello  all
my drivers side mirror dont work  --- have taken it apart and the problem is the internal electric motor  ---british part number 2063795  made in Holland by ilu ( looks like ) --- have found one on e bay  ( looks the same )  but is off mk3  ford  --- any one know if it is the same  as used by VW ?
If I want to take the whole mirror  off  do I have to take the door lining off to unbolt it   --- then I could just fit complete new mirror unit
cheers
Rob
Offline palmer
Re: electric heated wing mirror
« Reply #1 on: 10 November 2010, 20:42 »
just to let youall know  it is the same motor  on the Golf and the Ford
so once I get it from E bay  I can replace it  anf have a working electric motor  !!!!
cheers
rob
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #2 on: 11 November 2010, 09:19 »
Just change the mirror,It would be less hassle and you dont have to take the card off.
Fair play if you want to change the motor tho,Many like me wouldn't be arsed to  :wink:
« Reply #3 on: 11 November 2010, 09:42 »
I replaced the mirror on mine, seemed the easier option.
Offline Paul86S2
« Reply #4 on: 11 November 2010, 09:48 »
You can unbolt the mirror by just removing the  triangular inner door cover behind the mirror but you need to remove the door card to disconnect the wiring. Not a difficult job.
Paul
Offline palmer
« Reply #5 on: 11 November 2010, 12:43 »
forme  it seems easier  just to replace the motor  and cheaper  !     £25  for new mirror  plus a bit of  dismantling  v   £ 4  for motor  and easy refit
all you have to do is  " pop " the mirror off  and the motor  just unbolts with three  little  bolts and a star head screwdriver  undoes these
cheers
rob
Offline Len
« Reply #6 on: 11 November 2010, 12:49 »
If you post some piccies this would be a candidate for the Info section.
www.sas.org.uk
www.the-ace.org.uk
Offline palmer
« Reply #7 on: 11 November 2010, 18:44 »
i will  but dont know how to " post pictures "  can you explain  how to post them  very simply to me
cheers rob
