Author Topic: Rough idle + vibrations?  (Read 2996 times)
Offline Noah77
« on: 04 November 2010, 14:02 »
I have recently bought a 2004 Golf GT FSI 2.0.
When on idle, it sounds like a diesel (which I know is normal) and the engine seems to move around a bit under the bonnet - it sometimes causes some vibrations in the car (not always though).
I've heard it's supposed to be normal, but it's SO annoying when sitting in traffic! Is there anyway to smooth out the idle? Perhaps the MAF sensor could do with a clean/replace?
There's no probs with the car, no warning lights, it always starts and has just had the Cambelt, water pump and tensioner changed plus a long life service. I also always fill it with premium unleaded...
Done just over 44,000 miles.
My old MK4 GTI did the same thing so I assume it's normal, but it's just so annoying, I really want to find a way to stop it vibrating.
Offline Phil1980
Re: Rough idle + vibrations?
« Reply #1 on: 04 November 2010, 15:44 »
One of those things that you just have to get used to, sounds like you have replaced everything that you need to.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline Jimp
« Reply #2 on: 04 November 2010, 15:49 »
It's normal. Even my 1.4 does it from time to time.
Not low enough mk5
Not on the road enough mk3
Offline Noah77
« Reply #3 on: 04 November 2010, 17:06 »
Would cleaning or replacing the MAF sensor do anything?
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 04 November 2010, 17:28 »
Does the vibration stop when you press the clutch pedal?
Offline Noah77
« Reply #5 on: 04 November 2010, 17:40 »
No, seems to sometimes vibrate and other times it's fine.
No pedals make a difference. No vibrations after about 1500 revs.
Offline Phil1980
« Reply #6 on: 04 November 2010, 17:41 »
Normal.
