Author Topic: Praise be, Think ive found the cure to stuttering/stalling  (Read 7231 times)
Offline Overseer
Re: Praise be, Think ive found the cure to stuttering/stalling
« Reply #10 on: 09 February 2005, 10:00 »
ahh.. you need this site ;)
"Ken's Digifant Page"
http://www.members.tripod.com/~fuelie/tuneup.htm
Offline Horney
« Reply #11 on: 09 February 2005, 10:39 »
What an excellent read! I've printed that off and will be going through it tonight.
Many thanks,
Offline Overseer
« Reply #12 on: 09 February 2005, 10:46 »
no probs.. cant remember how i found it last night.. i'd seen it before though..
most of the stuff on that list has been done to my motor (inclcidng regular "italian tune-ups") apart from checking the PSV for a leak.. i might check the distributor sometime too..
Offline Horney
« Reply #13 on: 09 February 2005, 10:48 »
I'm picking up some new leads, dizzy cap and rotor arm at lunch to, so hopefully (everything crossed) I'll be on the road to recovery!
Offline Justins145bhpMK1
« Reply #14 on: 09 February 2005, 12:05 »
I cant see how disconnecting the MAF would have much of an effect on the CAT to be honest.
Offline Horney
« Reply #15 on: 09 February 2005, 12:11 »
You'll be running a much richer mixture as the ECU will default to a richer setting. Rich settings cause to much unburnt fuel to pass into the CAT which over a period of time will damage it.
Offline Overseer
« Reply #16 on: 09 February 2005, 14:32 »
^ Yup!  :cool:
« Reply #17 on: 09 February 2005, 15:49 »
Right I have reconnected the MAF for the time being, back to sh*tty performance till I get a new one!!
Offline Overseer
« Reply #18 on: 09 February 2005, 16:06 »
thing is.. you could find that it is inadvertently making the problem going away.. replacing it could do nothing as the cause could lie elsewhere..
Offline AudiA8Quattro
« Reply #19 on: 09 February 2005, 16:44 »
You shouldn't be able to damage the cat, as a lambda sensor will be fitted. This will automatically lean out the mixture.
