Author Topic: Praise be, Think ive found the cure to stuttering/stalling  (Read 7229 times)
Offline Jamie
Re: Praise be, Think ive found the cure to stuttering/stalling
« Reply #30 on: 10 February 2005, 17:16 »
OK, this sounds very much like the problem I am having at the moment with my mk.3 1800 Driver, can't seem to find the MAF, and the reason may be that it may not have one on the 1800 SPI engine.  Anyone know for sure either way, and any thought on what it could be otherwise after replacing most of the ignition system (bar ECU), air and fuel filter.  Its been on diagnostics, but nothing could be found.  Just about to give up on it.
Jamie
Offline AudiA8Quattro
« Reply #31 on: 11 February 2005, 00:19 »
I've got a mk3 bentley manual if thats of any use, should have all the test procedures in it.
Philgti, i've never heard of a clutch switch, is that fitted to mazda's?
Offline Resevoirfrogs
« Reply #32 on: 17 February 2005, 14:30 »
Latest update on my ill car...
As you can guess the car messed up again last night in the middle of rush hour traffic, :embarassed: but unlike usual where i switch off the ignition and switch it back onto clear the fault, it wouldn't re-start.  :cry: The starter motor was turning over ok, but the engine would not fire (no 'chugging' as if it was trying to turn over) and the oil light began to flash...
AA to the rescue!
Called out the men in yellow. He diagnosed the problem within 2min saying he'd seen it before. The spark plugs weren't firing. He put some fancy machine on the distributer and had it running in minutes. He said it was a fauty regulator on the back of the coil. By stroke of luck he had the exact part in the back of the van. Unfortunately you cant buy it separately as it come as part of the coil assembly. ?87 and 5 minutes later the car was running again.
Hopefully this will have cured my problem. He said that the intermittent fault wouldn't show up on a computer because it doesn't occur when the car is warm, which ties in with my problems only occurring within the 1st 5 minutes of driving.
Dont know if you guys have change this part yet? May be worth a try?
Offline Overseer
« Reply #33 on: 17 February 2005, 15:31 »
sort of.. mine conked out one day (when ragging it  :laugh:) and needed the coil replacing.. up to then it would stutter/stall before sometimes. fine since.
