Author Topic: Bens Mk3 GTi VR6, Twin Turbo build is starting  (Read 181554 times)
Offline tshirt2k
  • Been there...Done that...
Re: Bens Mk3 GTi VR6 project
« Reply #340 on: 19 November 2011, 17:22 »
:undecided: looking at that picture, the things on the front of the inlet manifold what are they, guessing extra injectors?
They are the pipes for a nitrous system. Gas and fuel.  :wink:
Mk3 ABF 16VT Megasquirt V3
Offline tshirt2k
« Reply #341 on: 19 November 2011, 17:32 »
To simplify the pipe work I'd think about a modded short inlet. There's a guy, powernut with the R32T 4x4 caddy that seems to make and weld them for fun. Might be worth a chat.
« Last Edit: 20 November 2011, 08:48 by tshirt2k »
Offline Dmonday
« Reply #342 on: 19 November 2011, 18:28 »
f**k it, VR6TTTT :lipsrsealed:
Nah plans sound good though ben looking forward to this! ;)
Offline Bellend
« Reply #343 on: 04 March 2012, 14:41 »
How's the turbos coming along?
When you converted to VR6, how did you sort the clutch issue out? New pedal box or a conversion thing?
Where all my moneys went.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #344 on: 04 March 2012, 14:44 »
Convrted to Hydro as per normal VR6 and 16v cars have, we used the VR6 clutch and gearbox.. basically full set up from donor car
late mk3s all have same pedal box wit provisions to take hydro set up, early cars like mine don't so need a late pedal box fitting as mine did for my conversion
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Bellend
« Reply #345 on: 04 March 2012, 14:53 »
OK thanks mate. Mines on an N but has most late features. I'll have probs have a look. Is it obvious if it has both?
Offline F17BAD
« Reply #346 on: 04 March 2012, 15:39 »
it will have late pedal box  :wink:
Offline Bellend
« Reply #347 on: 04 March 2012, 17:32 »
AWESOME news.
Really wasn't looking forward to swapping it out. So do I need to cut the bulkhead? Cheers for the info mate, didn't wanna ask in the MK3 section, wanted an answer I could trust.  :wink:
Offline F17BAD
« Reply #348 on: 04 March 2012, 17:34 »
no mate don't need to cut anything for this application :-)
what you planning ?
Offline Bellend
« Reply #349 on: 04 March 2012, 22:52 »
Just a VR conversion some time. :)
