Author Topic: Bens Mk3 GTi VR6, Twin Turbo build is starting  (Read 181593 times)
Offline Timberland
Re: Bens Mk3 GTi VR6 project
« Reply #350 on: 06 March 2012, 19:22 »
those are very nice plans,
With the exhaust manifold, are you gonna make 2 manifolds? 3 pipes per turbo?
Or otherwise?
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #351 on: 06 March 2012, 23:31 »
Hello, been a while  :smiley:
Timberland, yes I will be running 1 turbo per 3 cylinders but it wont be happening until the end of the summer now, my wedding is at the end of May so need to get that out of the way before I tackle this project  :angry:
I will be running 2 x K03 turbo's with twin side mounted intercoolers, i will be relocating the washer bottle to the opposite side of the bay (mk4 bottle) and running a cone filter a lal F17BAD.
The intercooler pipework is going to be fun to get looking right as I'm keeping the existing VR throttle body and intake/plenum, Im not going to use an aftermarket short intake, pipework aside, I want to keep the bay looking as oem as possible.
I have been busy over the last couple of weeks tho getting little bits an bats sorted
Pic heavy update to follow  :cool:
Offline benvictors
« Reply #352 on: 07 March 2012, 00:02 »
Here goes
Took my splits off for the winter and decided I was bored of the red so set about stripping them
The joys of being an engineer
Snapped one of the titanium bolts when splitting  :shocked: :shocked:
Gone for a satin steel type look for the rim, no paint but not quite polished
Offline benvictors
« Reply #353 on: 07 March 2012, 00:09 »
Had to drill out the smapped bolt and damaged the thread in the rim so came up with the idea of re-tapping bigger and making a bolt
Machined the head of a standard high tensile hex head bolt
Got myself a 2.9 intake for the princely sum of £10.50
Along with a spare throttle body for £5.00 which I boshed straight on the machine to port
Offline benvictors
« Reply #354 on: 07 March 2012, 00:17 »
Port matched the OBD2 throttle body to the OBD1 2.9 intake,
However, the holes to mount them together are in different places so I set about making an adapter/spacer plate
Had to mark up the intake for the new holes
Drilled
Tapped
And plate fitted, used some super dooper gasket seal shizzle I had lying around
And the throttle body fitted
BEAUTIFUL
Offline benvictors
« Reply #355 on: 07 March 2012, 00:22 »
The VR broke on me too the other night, coolant hose split clean in 2 pissing coolant all over my bay  :angry: :angry: :cry:
Had to get recoverd and ordered my new hose
Old
New
Fitting my new brakes, sorting a couple of rust patches, painting and fitting my new intake, all this weekend hopefully
Aaah, nearly forget
Offline SoundillusioN
« Reply #356 on: 07 March 2012, 10:05 »
Rare to see a hose go like that.  :shocked:
I had one blow in a similar fashion but that was caused by a faulty head gasket pressurising the system.
Offline VR6_Wherry
« Reply #357 on: 07 March 2012, 10:11 »
I just love the skillz that this man has :cool:
Going to be an epic build! :afro:
« Reply #358 on: 07 March 2012, 10:16 »
I didn't look high enough up the page.  just seen all the machining work.  :cool: :cool:
I want all that gear in my shed!
Offline Timberland
« Reply #359 on: 07 March 2012, 11:47 »
that's very common place for that coolant hose to rupture.
I've personally changed every coolant hose for the black Samco's
The hoses on a vr6 will having a hard time.
BUT i LOVE the machinework!! :laugh:
Very nice work mate
