Author Topic: best thing to stick g60 arches  (Read 1669 times)
Offline popleyruss
« on: 26 October 2010, 20:34 »
Right then how and what shall I use andvadvise please also the sill sideskirt I need to stick on aswell do they bolt on?
Just plain dubbin
Offline Thom89
  • Looking for an "Icebreaker"
Re: best thing to stick g60 arches
« Reply #2 on: 26 October 2010, 21:00 »
Bonded windscreen adhesive, from ebay :wink:
Thom
« Reply #3 on: 26 October 2010, 21:20 »
As above or tigerseal
Offline dan_apps
  • too low for british roads!
« Reply #4 on: 26 October 2010, 22:18 »
or sikaflex....thats how my rusty mk2 was held together! does work very well!
Offline lewis1641
  • stuck in the 90's
« Reply #5 on: 27 October 2010, 11:21 »
my arch trims are held on with tigerseal. they are holding fast and tight despite having a few impacts with the rear rims
« Reply #6 on: 27 October 2010, 11:56 »
sils you need a fitting kit dfrom vw. this consists of a long strip plus some small plastic clips. you bond these to the sills and put a screw in either end. arches you should rivet on unless your wings are shot
Offline Neo Badness
  • Feet are for pedals
« Reply #7 on: 27 October 2010, 12:31 »
Tigerseal, bodyline, sikaflex are all exactly the same stuff just in different wrappers...
Fitting kit would be ideal but sikaflex would do the trick.
