Author Topic: Smoking issues  (Read 5856 times)
Offline Mobby
Smoking issues
« on: 23 October 2010, 17:19 »
I have a golf GTTDI with a allard egr delete, forge FMIC and a brand new AFM and a Remap from R-tech performance.
Now my car smokes really bad!! black soot whenever in the boost range, soots up the back of the car. Its bloody annoying and im sure this isnt the norm for remapped tdi's. The supplier of the remap has now stopped using that map and now use a Revo map.
The two last things it could be is turbo and injectors? can injectors really make your car smoke that bad???
The fact it has a petrol backbox dosnt help keeping it off the car or causing a swirl?
I will record a video soon.
Any input would be great :-)
Offline sparks03
  • Look at the veins in that
Re: Smoking issues
« Reply #1 on: 23 October 2010, 17:23 »
Injectors on the way out usually cause a diesel to look like a startled squid under acceleration. Might be worth getting them checked out. Have been telling the mrs she needs new ones on her Mondeo for ages, bloody embarrasment when you get your toe down.
<br />   Heaven is 13 feet long
Offline Mobby
Re: Smoking issues
« Reply #2 on: 23 October 2010, 17:45 »
Thanks for that, my mates got some injectors for sale PD150 ones so ill buy them now :-)
Re: Smoking issues
« Reply #3 on: 23 October 2010, 20:52 »
It might not be the injectors, overfueling will cause it and that could be down to the map or a few other issues.
Offline bobotheclown
Re: Smoking issues
« Reply #4 on: 23 October 2010, 21:03 »
glow plugs would be the first thing to look at. quite a cheap and easy to do yourself fix
Offline Rhyso
Re: Smoking issues
« Reply #5 on: 23 October 2010, 22:47 »
Glow plugs??  :huh:  They're only used when starting the car.....
Remapped TDI's WILL smoke after a remap.  If its excessive smoke then chances are you've got a boost leak somewhere in your system
What map are you running now as you state its an R-Tech map then say they've stopped using it and put a REVO one on? R-Tech supply their own maps as well as REVO
Offline topher
  • Administrator
  • fully functioning
Re: Smoking issues
« Reply #6 on: 23 October 2010, 22:52 »
agreed, especially if it's only started happening recently. weak pipe connections can begin to fail quite quickly after a remap.
Offline alex160
Re: Smoking issues
« Reply #7 on: 24 October 2010, 09:36 »
I have got a revo remap on my golf and it deosnt smoke too bad under load. As said, sounds like a possible boost leak.
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
Offline Mobby
Re: Smoking issues
« Reply #8 on: 24 October 2010, 09:47 »
Thanks for all the positive replys guys. really beggining to like this forum.
The smoking happend since i got the car remapped.
It has had a forge FMIC system fitted with all the pipes replaced and it still soots my car up. i will definetly get a video monday for you guys.
Could the map sensor have anything to do with it?
Offline Rhyso
Re: Smoking issues
« Reply #9 on: 24 October 2010, 10:29 »
What engine you running?  I'm assuming by having a Forge FMIC fitted its the 130
Need to do some logging and view the boost and injector logs
