Author Topic: dont really understand whats going on....!  (Read 3237 times)
Offline -HellRaza-
« on: 01 February 2005, 15:27 »
hey,
? ? ? ?im posting this on behalf of my brother....
Basically, hes recently installed a 400watt jbl ampifier he got cheaply from a friend, powering 2x vibe rectangular 800watt 6x9's,? since it was installed it has been cutting out part of the way through a song, which is a pain in the arse! and im unsure as to whats causing it... wiring is fine, and the amp itself seems to be a-ok! any suggestions would be most appreciated!...
? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?cheers
? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?alex
« Last Edit: 02 February 2005, 11:38 by -HellRaza- »
mrwotto
Re: dont really understand whats going on....!
« Reply #1 on: 01 February 2005, 15:58 »
I think this would be better moved or reposted in the ICE section.
Paul
Offline Overseer
« Reply #2 on: 01 February 2005, 16:08 »
i'd suggest checknig the earth for the AMP is good.. thats usually the reason they cut out randomly
Offline bunter
« Reply #3 on: 05 February 2005, 18:29 »
id also suggest checking that the amp its overheating as the thermal cut out would stop the amp. Also if u have the gain turned up too far and the speakers are trying to draw too much power from the amp then the amp will clip and cut out. :cool:
