Author Topic: Rear brake carrier removal help - please!  (Read 4416 times)
Gavv8
Re: Rear brake carrier removal help - please!
« Reply #20 on: 02 October 2012, 19:15 »
I always use this,works a treat on them and also the cross head screws that hold the front discs in place that are made of cheese.
When you tw*t the end the other end twists and does striaght away.
Never failed me yet.Oldskool tools ftw!
If you want to borrow it just gimme a shout.
I've got one of these and they are good but there is nowhere near enough space to use one on the top bolt, i use heat and just kept flexing the extension bar until they cracked and came out but i'm replacing them with hex bolts for future ease of removal when i replace the rear beam with a fresh set of beam bushes.
Offline Metallix
« Reply #21 on: 03 October 2012, 08:51 »
Up on a ramp, access was fine  :evil:
You could jack it up high & undo the bolts to the shocks, letting beam swing down
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #22 on: 03 October 2012, 09:00 »
This is what i did last time, i also undid the exhaust backbox mounting point so i could get better access to the upper nearside bolt.
