Author Topic: starting and stalling probs  (Read 2100 times)
Offline Ronnievdub
« on: 31 January 2005, 23:52 »
hey folks,
just a note for any MK3 GTi owners who're having troubles with starting or stalling problems.
i went today to my local VW dealer and spoke to one of the mechanics about my recent problems with my GTi playing up. ( referring to my recent postings on the forum ). He plugged my Golf into the diagnostics and it came with a fuel fault. He cleared that but the problem with starting and stalling persisted.
he suggested to me the following as he suspected an earthing problem between the battery and the starter motor:-
1. disconnect & remove the battery.
2. unbolt the battery base plate ( there should be 4 10mm bolts holding it in place).
3. under the base plate there are two earth points. unbolt these from the bulkhead and using wet and dry remove any build up of rust and dirt.
4. clean up the two bolts and spray with good old WD40.
5. replace the two earth wires and bolt back down tight then cover the bolts and connections with a little spray grease.
6. replace the battery and clean up the terminals
there is also an earth wire located at the right hand side of the engine block, ( as you look at the engine ), again unbolt this earth wire and clean up til its free from rust build up.
dont know if this will work in the long run but ive certainly noticed a difference so far. theres no lag from the engine as i put the foot down and it starts a dream.
hope this is of some use to those who are having the same problem i did. you can let me know if this worked for any one else.
happy motoring
Ronnie
Offline PhilGTi
Re: starting and stalling probs
« Reply #1 on: 03 February 2005, 16:49 »
Did you just having starting problems, or erratic stalling as well?
Thanks
Phil
Offline Ronnievdub
« Reply #2 on: 04 February 2005, 20:14 »
it was mainly when i started it up it wouldnt idle on its own. then it would cut out for no reason. its running like new now so im putting my problems down to a few bad earths
are you having problems too?
Offline PhilGTi
« Reply #3 on: 10 February 2005, 08:39 »
Glad you got it sorted. My problem seems more serious, ie the engine can cut out whilst driving. I have had chance to put any test equipment on it yet.
Phil
Offline shabba_uk
« Reply #4 on: 10 February 2005, 09:35 »
my car has an ignition problem but its very similar to this. i just wanted to ask if the car stays started if you hold the key.
Offline PhilGTi
« Reply #5 on: 10 February 2005, 09:49 »
I haven't tried this, but I have given the key a good shake whilst driving and it didn't cause it to stall. It also just dies on the driveway when idling. The ignition barrel is a possibility, but I'm leaning towards on of the sensors. I plan to put an oscilloscope on the speed sensor and check some voltages. The worst issue is trying to get it to fault long enough to carry out the test.
Phil
