Author Topic: Stu's Mk3 1.8t [projectninetynine]  (Read 36705 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: Stu's Mk3 1.8t [projectninetynine]
« Reply #110 on: 12 February 2011, 22:01 »
well has just got a big scaffold tube going to try that with a 19mm socket
You should not need that to turn it over, take the plugs out and see if you can turn it over with a normal ratchet.
You do when its seized!
Offline Dmonday
« Reply #111 on: 12 February 2011, 22:10 »
Manage to un-seize her?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #112 on: 12 February 2011, 22:11 »
Yer think he did, moves freely now with just the rachet and no breaker.
Offline dom
  • Back in a Mk4
« Reply #113 on: 12 February 2011, 22:13 »
Good stuff :afro:
« Reply #114 on: 12 February 2011, 23:43 »
Well if it was seized then that will have done it no good at all, you might have broken a piston ring or done more damage.
Offline Dmonday
« Reply #115 on: 12 February 2011, 23:53 »
I know it's totally different engine but my mate managed to un-seize the engine in his corsa and on his mates astra by rocking it back and forth in gear for a while and was totally fine.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #116 on: 13 February 2011, 00:09 »
Yer, either that or strip it and f**k that for a laugh :D I wanna get it running!
Will be fine :rolleyes:
Offline stugolfmk3
« Reply #117 on: 13 February 2011, 11:24 »
yh just sounded a lil bit dry then put more oil in on the rods sounds a lot better now  :cool:
Offline SoundillusioN
« Reply #118 on: 13 February 2011, 12:22 »
Fingers crossed that everything is alright and running it doesn't cause more issues.
Offline stugolfmk3
« Reply #119 on: 01 March 2011, 19:08 »
car is painted and looks sh!t up
