Author Topic: Stu's Mk3 1.8t [projectninetynine]  (Read 39696 times)
Offline Dmonday
Re: Stu's Mk3 1.8t [projectninetynine]
« Reply #100 on: 11 February 2011, 08:19 »
f**k no waaay :undecided: feel your pain guys this seriously sucks! Hope you don't wait months before rebuilding like i did, wanna see this done :)
Dan
Offline LazyLunatic
  • MK3 20VT Project
« Reply #101 on: 11 February 2011, 08:40 »
Dan
I know, Stu said he couldn't turn it over by hand, I thought we had checked then when we first got the engine :(
Going to try again tomorrow, but it would make sense why the starter sounds like its turning over and just gets hot and smokes.
He's getting the spray shop to hurry up and get it done, so we can get it home and strip the engine down and see what's up. I'll be checking the wiring again though, so we can wrap it up and make all the spliced connection clear, labelled and any other loom connections secure, so we can just plug it all back in later and not have to worry about it.
Offline robz
« Reply #102 on: 11 February 2011, 08:57 »
gutted!
hope it makes easy fixing!!!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #103 on: 11 February 2011, 09:01 »
gutted!
+1!!!
Offline Dmonday
« Reply #104 on: 11 February 2011, 09:02 »
sh!t man :undecided: when my engine seized the starter just wouldn't go for it at all :huh: just clicked and got hot, has stu tried putting it in 2nd and rolling it over? might be a bit easier then turning it over by hand. :)
Dan
Offline LazyLunatic
  • MK3 20VT Project
« Reply #105 on: 11 February 2011, 09:02 »
Dan
We'll give it a go, thanks mate!
Offline stugolfmk3
« Reply #106 on: 11 February 2011, 17:27 »
well has just got a big scaffold tube going to try that with a 19mm socket
Offline stugolfmk3
« Reply #107 on: 12 February 2011, 14:21 »
crank is turning now  :cool:
Offline robz
« Reply #108 on: 12 February 2011, 20:06 »
Excellent hopefully not much damage then!!
« Reply #109 on: 12 February 2011, 20:19 »
You should not need that to turn it over, take the plugs out and see if you can turn it over with a normal ratchet.
