Author Topic: engine rattle at 3k  (Read 2089 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
engine rattle at 3k
« on: 15 October 2010, 21:56 »
I have an annoying rattle on my engine(2.0 gti 8v),its fine on tickover but at around 3k it develops a top end rattle and if you keep reving it dissapears.If i rev it up slowly its not as bad and is more noticeable under load.Its high mileage 157k but other than a puff of smoke at start up its fine,It is definately top end so can rule out big ends.
Anyone have similar problems before???
Offline Khare
  • The bear that khares
Re: engine rattle at 3k
« Reply #1 on: 15 October 2010, 21:59 »
Is it a tinny rattle? If so a common rattle is the exhaust downpipe heatshield. Try revving the car with your head under the bonnet and listen out around exhaust area. If it is the downpipe then the solution is 2 large jubilee clips joined together and tightened around the heatshield to stop it rattling.
Like so:
« Reply #2 on: 15 October 2010, 23:29 »
Try and post a video, always helps.
Offline 01664gti
« Reply #3 on: 16 October 2010, 06:16 »
I dont think its heat sheild,Its defo just under the rocker cover
Ill try and get a video tomorrow
Offline Khare
« Reply #4 on: 16 October 2010, 11:17 »
Could be the splash guard then.
Offline admc6
« Reply #5 on: 17 October 2010, 13:01 »
I have that on mine and that's the heat shield. Not got permanent solution yet, just a couple of spots of  exhaust putty help reduce it
Offline Khare
« Reply #6 on: 17 October 2010, 14:15 »
As I said in the first reply, try jubilee clips.
Offline AlexMozza
« Reply #7 on: 18 October 2010, 10:40 »
Worked for me when i had the rattle :)
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline jigger01
« Reply #8 on: 18 October 2010, 10:50 »
hi i had a loud rattle on mine . thought it was the cv joint ( grinding sort of rattle) it to was there under excellerastion it turns out after much investigation that a bolt in the sump that holds the crank inplace had sheered its head and was loose in the sump bashing around . just thought i would mention it .. :wink:
working progres
Offline Len
« Reply #9 on: 18 October 2010, 13:03 »
There is an alloy heatshield attached to the head just above the exhaust manifold. Check that!
www.sas.org.uk
www.the-ace.org.uk
