Author Topic: 8v P/S Pump and Drive  (Read 1661 times)
Offline Stirring Moose
« on: 14 October 2010, 18:48 »
Am trying to find some info on the power steering set up on the 8v GTI. I've had a quick go with the search function but no real luck. What I'm really looking for is any pictures of the pump and its drive belt as I want to check what differences (if any) there are between the 8v and 16v set ups. I'm designing a part that I want to be suitable for use on both models but I currently only have direct access to my car which is a 16v. If anyone has any suitable pics or info, I'd be muchos grateful if they could post them up.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
Offline Khare
  • The bear that khares
Re: 8v P/S Pump and Drive
« Reply #1 on: 14 October 2010, 18:53 »
Both the same mate, I used my 8v pas system with the 16v engine.
« Reply #2 on: 14 October 2010, 18:57 »
Thanks. Is bracketry etc. the same as well, and does pump sit in roughly the same place under the car?
S.M.
Offline Khare
« Reply #3 on: 14 October 2010, 19:03 »
Brackets all the same, and sits in the same area too as the engine blocks are the same.
« Reply #4 on: 14 October 2010, 21:55 »
As the engine blocks are the same.
16v has internal differencs
Offline Khare
« Reply #5 on: 14 October 2010, 22:20 »
I now it does....I'm talking about the block wayne  :rolleyes:
« Reply #6 on: 14 October 2010, 23:36 »
Yes but the block is different.
Offline AudiA8Quattro
« Reply #7 on: 15 October 2010, 00:02 »
Isn't the breather different on the block? or is that the mk2?
Offline Khare
« Reply #8 on: 15 October 2010, 01:10 »
Block is the same, as far as I know, but some stuff around it, like the breather is different.
« Reply #9 on: 15 October 2010, 11:25 »
the pas system is the same on 1.8-2.0 8v and 16v engines, the only difference is the alternator setup. early ones have a massive spring under the alternator, later models have a seperate tensioner pulley. both setups can be swapped though if you also change the alternator bracket. waterpump pulley is also the same, but crank pulley is different due to the abf having a thicker timing belt sprocket.
the physical block is the same between 8v and 16v, though the 2e block doesn't have a hole for a crank sensor. the pistons and conrods differ 8v/16v, also so do the intermediate shaft, oil pump and timing belt sprockets.  crankshaft has different part number, but i think its the same shape. something like abf is forged or something. not 100% sure?
BBM motorsport do an ABA->ABF conversion kit for the guys in the US, but I cant remember if a crank is included. I'd check but cant seem to get to their website
