Author Topic: Fiscon - in call use of number pad  (Read 1985 times)
Offline Mighty_G
  • Tornado Red MK6 3 Door, 18 inch rims, AAC, RCD510
« on: 11 October 2010, 17:13 »
Hi all,
Just bought a HTC desire from orange which is great apart from one annoying niggle. I drive a lot with work and use the fiscon a lot as a result, with orange when somone leaves me an answerphone message I can ring the asnwerphone using the on-screen shortcuts, however on orange when you get through to the answerphone you then have to press '1' for the messages (which I didn't have to do with 02), I've rung orange and they won't change it, so the alternative I tried was using the key-pad on the fiscon user-screen, however it doesn't work when you are 'in-call'.
Has anyone got it working, if so did you have to do something like an update or other configuration ?
thanks
Paul
Offline p3eps
Re: Fiscon - in call use of number pad
« Reply #1 on: 11 October 2010, 18:00 »
Its nothing to do with your phone - its a common complaint from Fiscon users.
Write to them and complain - perhaps the more complaints about it, then they will actually fix it.
Surely a simple software update could sort it?
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline Mighty_G
« Reply #2 on: 11 October 2010, 18:38 »
have sent them a note, but not holding out much hope.. :rolleyes:
Offline p3asa
« Reply #3 on: 11 October 2010, 23:06 »
Same here but I just press the number on the phone and all is sorted!!
Offline Mighty_G
« Reply #4 on: 15 October 2010, 17:46 »
problem with that is i have to take hand off wheel, pick up phone, swipe it to unlock, then press 1, not ideal when driving !!
Offline p3asa
« Reply #5 on: 15 October 2010, 17:56 »
That is a helluva lot easier compared to selecting audio tracks on the RNS/RCD 510
