Author Topic: handbrake cables  (Read 2667 times)
Offline daniel-1986
handbrake cables
« on: 09 October 2010, 21:55 »
my mk2 will need a new handbrake cable(s) for the mot (not done yet) as its at full adjustment at the lever and it barely holds the car on a hill, do they come in pairs or are they sold seperatly as gef and ecp dont say
Offline Sam.
Re: handbrake cables
« Reply #1 on: 09 October 2010, 21:59 »
seperately (Got mine from GSF)
EDIT: full adjustment in the car, at the drums or both?
Offline daniel-1986
« Reply #2 on: 09 October 2010, 22:03 »
in the car, dnt think theres a way to adjust them at the drums
Offline Ben Lessani
« Reply #3 on: 09 October 2010, 22:04 »
The adjusters on the lever ARE NOT to tighten the handbrake, its just to adjust the number of clicks.
Have a look on my project thread first post and click the link for handbrake tightening. You'll probably find the calipers just need winding in/out a couple of times to bring them back to life.
I'd grab the link for you, but i'm on my phone (mostly to wind up  x4mgs)
Offline Ben Lessani
« Reply #4 on: 09 October 2010, 22:07 »
ah, didn't see it was drums.
I've not wrote a guide for it, but usually drums have a little threaded rod inside them which acts as a ratchet (to allow for shoe wear). This can be wound in/out to adjust
When the handbrake is poor with drum brakes, it is usually just because the shoes are worn anyway.
Offline daniel-1986
« Reply #5 on: 09 October 2010, 22:17 »
ive changed the shoes and its no different and dont remember seeing any ratchet thing of any kind wen taking them off
the only adjuster inside the drum is the one circled which self adjusts
Offline Sam.
« Reply #6 on: 09 October 2010, 22:19 »
Those self adjusters rarely seem to self adjust immediately when they're put in again... Takes a bit of trial and error getting them moved manually.
This is a good read:
http://faculty.ccp.edu/faculty/dreed/campingart/jettatech/reardrum/index.htm
Offline daniel-1986
« Reply #7 on: 09 October 2010, 22:35 »
so i shud just hav a fiddle with that adjuster before spending money on hanbrake cables, only want it to get me thru the mot as im after a new car after xmas
Offline Ben Lessani
« Reply #8 on: 09 October 2010, 22:38 »
Just make sure you slacken off the cables before you begin ;)
Offline daniel-1986
« Reply #9 on: 09 October 2010, 22:45 »
cheers guys, may hav saved me £30.
its a job for tuesday
