Author Topic: MK3 GTI 8v won't start  (Read 1783 times)
Offline jarrattn
« on: 28 January 2005, 10:40 »
My Mk 3GTi 8v won't start. It is totally dead :-(, came out of the sports centre after an hour or so and it was just dead. It had started okay twice just before that after being parked all day at work.
The battery is okay, about 1 year old and fully charged.
Car won't jump start off another car.
Car seems like it will bump start if I could have got some help to push it a bit quicker.
The battery, oil and other dashlight come on and stay on when starting.
With headlights on the headlights dim on turning the ignition.
There is no clicking noise when starting.
There is a slight buzzing noise, from somewhere - can't tell if is under the dash (fuses ?) or engine bay.
So it seems like a dodgy starter motor to me ? Or maybe the starter relay or solenoid or wiriing ?
Any suggestions as to what to check first ? Before going out any buying any new parts.
Thanks, Neil
mrwotto
Re: MK3 GTI 8v won't start
« Reply #1 on: 28 January 2005, 13:13 »
Wont be the solenoid as that is working as the way i would check to see if a solenoid was working is to see if the lights dimmed when i tryed to turn engine over, so to me it sounds like the starter motor mate.
Paul
Offline Tucker
« Reply #2 on: 28 January 2005, 13:28 »
Sounds like a starter to me, give it a tap with some one holding the key on and she if she goes :wink:
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline Mr Blue
« Reply #3 on: 28 January 2005, 13:28 »
i think that clicking noise is from the relay. yeah i would say do a bench test on the starter motor
mrwotto
« Reply #4 on: 28 January 2005, 13:31 »
also try putting the car in gear and rocking it backwards and forwards, that sometimes will free a seized starter motor.
Paul
Offline adyh
« Reply #5 on: 28 January 2005, 16:24 »
The rocking has been known to work .
Do all the lights come on and go off [ i.e. airbag and ABS ] ?
If they dont then i reckon its the battery, it takes a lot of power to get these things started with all the extra stuff they have on them .
I might be that your imobiliser is not getting enough power . Ive tried to bump start mine in the past with no luck at all .
Offline jarrattn
« Reply #6 on: 29 January 2005, 07:58 »
Thanks for the tips. I will give it a go this morning and let you know the results.
Cheers, Neil
Offline jarrattn
« Reply #7 on: 29 January 2005, 23:50 »
Car will bump start.
I definitely seems like a starter motor overhaul.
Neil
