Golf mk3
hardmonkeys
clutch kit recommendations???
Topic: clutch kit recommendations??? (Read 1766 times)
wrobstar21
GTI forum regular
08 October 2010, 09:24 »
Hi all,
Im going to be changing my gearbox soon, any recommendations on which kit to get eg organic, fast road, standard etc....
1996 16v gti, gonna be getting a second hand box
cheers
rob
Wayne
Sir Postalot
Re: clutch kit recommendations???
08 October 2010, 09:27 »
Standard Sachs or Luk will be fine, you only need uprated if your running a lot more power.
wrobstar21
GTI forum regular
08 October 2010, 09:29 »
totally std engine so no more power!
how much you reckon and any idea on the best place to get one? seen loads on ebay but not sure as to the quality etc!
gsf you think?
Khare
Serious forum addict
The bear that khares
08 October 2010, 10:13 »
Are you planning on giving the gearbox or the engine a makeover while it's out? It might be an idea to do some major things while it's out if you want to save money and time later in it's service life.
wrobstar21
GTI forum regular
08 October 2010, 10:19 »
what would you suggest???
Khare
08 October 2010, 10:23 »
Well the 16v's weakness is the diff, I think it's the same on a few other gearboxes too. The diff is riveted on and it is known for 'boxes with miles on them to blow due to the diff coming apart. There's a bolt kit you can buy, this sorts out the problem completely as it exchanges used and word rivets for some strong bolts. However this job means taking the gearbox completely apart so it is a job for a specialist or a competent DIY person. I've never done it, so I can't tell you exactly what's involved in doing so but I'm sure others can.
wrobstar21
GTI forum regular
Reply #6 on:
08 October 2010, 10:27 »
i looked at lsd for them but at 500 quid its a bit steep although maybe i could try and source one with lsd already in it?
a longshot though i reckon!
cost is a bit of an issue here, hence the second hand and not a recon!
Khare
Reply #7 on:
08 October 2010, 10:34 »
If cost is an issue then a box with an LSD won't be cheap. As you said, £500 new thereabouts, however according to Ess_three it does transform the car completely.
Paul86S2
Reply #8 on:
08 October 2010, 11:20 »
I got my Sachs clutch kit from
www.vwspares.co.uk
they were the cheapest at the time.
No need for uprated on a standard engine. I went for the Sachs clutch kit because they have a good reputation and I didn't want to have problems later on by fitting a cheap quality one.
For some reason the VR^ clutch kit was a few quid cheaper but also fits perfectly so I bought that one instead.
Paul
Golf mk3
hardmonkeys
