Author Topic: Phase  (Read 2104 times)
Judderi
Phase
« on: 27 January 2005, 17:22 »
What is the phase setting that you get on amps?
Offline Dizzie
  • Make friends with your fast
Re: Phase
« Reply #1 on: 27 January 2005, 22:39 »
basically when the speakers are connected + to + and - to - they are in phase. what the amp does it let you swap this over without having to rewire them. sometimes when running 2 identical subs running one out of phase can improve the sound.
Mk4 Golf 150PD
Judderi
Re: Phase
« Reply #2 on: 28 January 2005, 10:31 »
Ah i see. So if you have them wired up correctly its probably best to leve the phase at 0?
Offline tobz.
Re: Phase
« Reply #3 on: 28 January 2005, 10:46 »
If everything is wired correctly then yes leave the phase shift as it is. You'd soon know if you have something out of phase because you would lose most of your bass and the system would be uncomfortable to listen to for extended periods.
I used to have a subwoofer with two 12" drivers that pointed inwards at each other, in that instance the two speakers HAD to be run out of phase with each other for the box to work as designed. That's just an example of when you would want to use phase switching.
You got any pics of your dad's split ?
