Author Topic: rebore?  (Read 2072 times)
Offline Woppit
rebore?
« on: 05 October 2010, 21:24 »
ok i was wanting to fit a gti lump into my golf but the work will take too long with the looms and keys, box, hubs, blah blah,
So would it be possible to rebore my AEX 1.4 to a 1.6? is there any room there to do it without compromising engine strength? ta
Re: rebore?
« Reply #1 on: 05 October 2010, 21:34 »
Nope not really, better to fit a 1.6 to be honest.
Offline Woppit
Re: rebore?
« Reply #2 on: 05 October 2010, 21:41 »
do i not again have to change the loom ecu and key with that one? i really dont want to do that
Re: rebore?
« Reply #3 on: 05 October 2010, 21:44 »
In that case you stuck with the 1.4, anything else will mean wiring and ecu plus uprating the brakes.
Offline Woppit
Re: rebore?
« Reply #4 on: 05 October 2010, 21:51 »
 :cry: shame, i would have thought it could've been rebored... but hey ho
Offline Jimp
Re: rebore?
« Reply #5 on: 05 October 2010, 21:51 »
Depending on the engine code it's not even bore that give it the displacement. It's a mixture of head shape and pistons/crank/a few associated bits. Some Polo modders use this fact to mix'n'match heads and blocks.
Not low enough mk5
Not on the road enough mk3
Re: rebore?
« Reply #6 on: 05 October 2010, 21:55 »
Yes it can be rebored but to get to a 1.6 or close would mean changing the crank to increase the stroke.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: rebore?
« Reply #7 on: 05 October 2010, 21:59 »
If i remember correctly the A series short block engines are all the same anyway
1.0L, 1.4L, 1.6L They have different porting in the heads (i guess)  and im not 100% sure but im pretty sure its just the stroke thats different between the 1.4 and 1.6, be honest i cant remember.... swapping pistons and head can/may be as simple as that
But the point is...  for the sake of swapping a loom you would be mad to think a re-bore is easier! Engine swap = big improvements, lots of self satisfaction,  and its much easier ... really it is, doesn't seem it but it is!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: rebore?
« Reply #8 on: 06 October 2010, 08:17 »
a proper re-bore and hone isn't cheap for starters, then you've got labour time to strip the whole engine down, while its apart new bearings, seals etc - would cost more and take longer than just doing a swap
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline Rmachines
Re: rebore?
« Reply #9 on: 06 October 2010, 16:58 »
Full engine overhall your looking £700 ish  Without a rebore!
And its madness not to overhall everything and replace what is nessasry while its out!
