Golf mk3
hardmonkeys
Top mount nut
Topic: Top mount nut (Read 2458 times)
vdubnut
Here all the time
Re: Top mount nut
Reply #10 on:
18 October 2010, 18:57 »
"Would using a 12v impact driver be up to the job of removing the nut.".... worked on mine
used a modifed deep socket for the lower nut (ground flats on so could hold with spanner long allen key through middle
Bellend
Re: Top mount nut
Reply #11 on:
18 October 2010, 19:02 »
If you aren't using your shocks again a file on the edges (with the wheel off) and a spanner on that works.
Where all my moneys went.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Top mount nut
Reply #12 on:
19 October 2010, 10:05 »
another option is cut up the upper plate that pokes inside the bay enough so you can remove the shock.
21mm for old nuts, 22mm for new nuts. shocks can be 6 or 7mm allen too
leegt5
Re: Top mount nut
Reply #13 on:
19 October 2010, 18:57 »
Used a 12v impact wrench on mine and it worked fine !!
Support London's Air Ambulance
FLOYDMAX
Re: Top mount nut
Reply #14 on:
19 October 2010, 20:38 »
I used a buzz gun to loosen top mount nut,,but cant loosen the nut that holds on the top mount and bearing
rubjonny
10k hero
Re: Top mount nut
Reply #15 on:
20 October 2010, 09:58 »
you need spring compressors to loosen that nut. once the tension is taken off the nut will probably be finger tight
FLOYDMAX
Re: Top mount nut
Reply #16 on:
20 October 2010, 20:14 »
Done that and its still solid,,,,,i will try again this weekend<<<<if its dry
Golf mk3
hardmonkeys
Top mount nut
