Author Topic: few poblems with my mk3 golf gti 8v  (Read 1635 times)
Offline mk3dan
  • low and for show
« on: 01 October 2010, 16:02 »
hi  guys and girls im have a few probs with my car
1st off im having problems with a relay the one with the number 30 on it would just like to know what this relay controls
2nd thing is my car wont rev over 5000 what could this be
thanks dan
Offline Deano2711
  • 1992 VR6
Re: few poblems with my mk3 golf gti 8v
« Reply #1 on: 01 October 2010, 18:00 »
Not revving over 5000rpm means the timing is out and it's gone into safe mode. Could be the hall sender or the dizzy Mate.
Offline dom
  • Back in a Mk4
« Reply #2 on: 01 October 2010, 18:03 »
It's not necessarily that the timing is out, when I had the problem my timing was spot on it was just a faulty hall sensor  :wink:
As for the relay, just replace it!
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 01 October 2010, 18:07 »
How difficult was it to change the hall sensor Dom or is it easier just to change the entire dizzy ??  Mine has gone into safe mode and is giving the hall sensor fault code. I have the parts on the car I am breaking but because of the rain can't get to have a look under there yet  :smiley:
Offline mk3dan
  • low and for show
« Reply #4 on: 01 October 2010, 18:07 »
thanks guys relays on order from vw and is it worth having someone put it on a computer to see what fault codes come up
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 01 October 2010, 18:52 »
Defo worth getting on a Vag Com or fault code reader Buddy as this should give you a code Mate.
Offline Khare
  • The bear that khares
« Reply #6 on: 01 October 2010, 18:54 »
Relay 30, that's the ECU relay, which could be something to do with the 5000rpm limit. If the relay doesn't solve it then it's either a dodgy hall sensor or bad timing, however if you've not had a recent cambelt change the it's likely to be the hall sensor as the timing wouldn't have changed by itself.
Offline dom
  • Back in a Mk4
« Reply #7 on: 01 October 2010, 18:55 »
@Deano Easier to change the dizzy, especially if you've already got another one that you can just swop over  :smiley:
@mk3dan: as Deano has just said def get it scanned with a Vag Com  :smiley:
Offline mk3dan
  • low and for show
« Reply #8 on: 01 October 2010, 19:16 »
sweet ill get it booked in for monday morning and hopefully get it sorted
thanks for the help guys
dan
