Author Topic: mk4 sub and amp  (Read 1890 times)
Offline mcgee9t2
mk4 sub and amp
« on: 30 September 2010, 21:19 »
ok proberbly been asked a milion times before but here we go.
were is the easiest gromet to go through for a power cable to wire up the ap to the battery?
and if i need a distrobution block or battery box (what ever you prefer to call it) to connect the wire to to battery, were do you guys get yours from?
cheers
Offline troublestarter
Re: mk4 sub and amp
« Reply #1 on: 30 September 2010, 21:45 »
the best grommet is up behind the rear of the passenger airbag
to do it properly you need to remove the front section of the centre console and the glove box when you have done this you then pull the white material out of the way and look up at the bulkhead and there will be a large grommet
this comes out under the windscreen on the passenger side behind the pollen filter
the cable can then be routed through the original plastic loom housing heading down towards the battery for a proper discrete installation
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
