Author Topic: lots of q's  (Read 2952 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
lots of q's
« on: 29 September 2010, 16:55 »
i have so many questions to askk
im trying to sort my car out today so yeah :P
right...
1. i have an oil brether pipe whice code is likely to be the part number?  7MO 103 211 A (7MO 493J)
        037 103 211 (493 AB)
        211 A (493 AE)
        211 D (493 AG)
        211 H (493 AP)
        211 E (493 AK)
2. My car came on plates H138 ERY even though its a 97' P plate golf, How do i find out my original reg?
3. Rang up a garage about cam belt change, they want £200ish is it hard to do it yourself?
sorry for all the posts, just need a hand!
Offline tobybrennan
Re: lots of q's
« Reply #1 on: 29 September 2010, 18:21 »
is the cars original reg on the car anywhere? :S
Offline Ardz83
Re: lots of q's
« Reply #2 on: 29 September 2010, 18:23 »
Try ringing the dvla mate.
Christo77
Re: lots of q's
« Reply #3 on: 29 September 2010, 18:30 »
£200 for a cambelt change.. 16v you have?   even so that's a fair whack for a belt change..
I've been quoted under £100 all in..and that's with a good reputable company top mechanic.. 8v that is..
Offline tobybrennan
Re: lots of q's
« Reply #4 on: 29 September 2010, 18:35 »
nah mines 8v mate
i normally pay quite a bit for work
may be cus i go to a specialist =/
Christo77
Re: lots of q's
« Reply #5 on: 29 September 2010, 18:50 »
The place i go are specialists.. from what i hear £70-80 is a good going rate for an 8v cambelt change..a bit more if you go quality company.. £200 sounds more than double in my book..
Offline tobybrennan
Re: lots of q's
« Reply #6 on: 29 September 2010, 18:52 »
yeahh it did sound a lot to me
he reckons the cambelt £80 and 2 hours work so...
Offline Dan_GTi8v
« Last Edit: 29 September 2010, 19:56 by Dan_GTi8v »
Re: lots of q's
« Reply #8 on: 29 September 2010, 20:44 »
Do a online mot check and see if the old reg is shown on hpi it, that will 100% tell you.
Offline Khare
  • The bear that khares
Re: lots of q's
« Reply #9 on: 29 September 2010, 20:49 »
cambelt is not that hard to do, as long as you don't move the pulleys when they have no belt then you're fine. Bottom pulley has to be removed though so the cambelt cover can be taken off. Sometimes the pulley bolts get rounded off or seize so they are the biggest problem when doing this job.
