Golf mk3
hardmonkeys
VR6 ABS issue
Topic: VR6 ABS issue (Read 840 times)
VW BUSH
Guest
VR6 ABS issue
28 September 2010, 19:05 »
Right,
All sensors changed
Rings cleaned
No fault codes
ECU Reset
ABS light comes on but no vibration from the pedal preceding it.
Where do I go next?
P reg VR6
AudiA8Quattro
Forum addict
Re: VR6 ABS issue
28 September 2010, 20:34 »
I would put the car on VAG com measuring blocks to check if it is registering each wheel speed.
Is the ABS light on all the time? i take it the brakes are locking up.
VW BUSH
Guest
Re: VR6 ABS issue
28 September 2010, 21:18 »
Have not had the right time to test the brakes yet, but the light comes on at ignition and stays on or just comes on while driving. I have a signal from each sensor too......
AudiA8Quattro
Forum addict
Re: VR6 ABS issue
28 September 2010, 21:20 »
Get someone to read the wheel speed on each wheel on VAG com, or have you already done that?
If all else fails i suspect the problem is the ECU.
VW BUSH
Guest
Re: VR6 ABS issue
28 September 2010, 21:26 »
Vag com shows wheel speed in normal limits, what about relays or abs pump?
AudiA8Quattro
Forum addict
Re: VR6 ABS issue
28 September 2010, 22:02 »
OBDII has pump and ECU as one unit.
You could try the relay, but i suspect the ECU.
jimmyb
GTI forum regular
Re: VR6 ABS issue
Reply #6 on:
30 September 2010, 18:08 »
maybe a dodgy abs pump,is the light on all the time? was it on when it was vag-commed?
Golf mk3
hardmonkeys
VR6 ABS issue
