Author Topic: URGENT PLEASE  (Read 4993 times)
Offline oliver07
  • golf gti T 200BHP
URGENT PLEASE
« on: 26 September 2010, 16:41 »
GUYS NEED HELP PLEASE.
Just in the middle of changing the oil on the golf oil out but the sump plug wont tighten looks like the threads are coming to bits !
I need the car to get to work in the morning I have a tube of universal blue gasket and joint compound will this work .
or any other ideas as cant get a new sump plug locally today
Offline houston
Re: URGENT PLEASE
« Reply #1 on: 26 September 2010, 16:44 »
as a short term fix, try puttin 2 washers on the plug and see if it tightens.
id be worried about using any gasket seal on the plug, it will most likely leak if theres no 'bite' on the threads
Offline Ant1981
  • Feed me, prod me
Re: URGENT PLEASE
« Reply #2 on: 26 September 2010, 16:44 »
sh!t, I feel for you mate. Not sure what else to do apart from a new plug, or even with the use of a helicoil, but as you say, you can't get anything today. Eeeek  :undecided:
'09 Kawasaki Ninja ZX-6R
Offline GOLF_STU
  • THE_GIT
Re: URGENT PLEASE
« Reply #3 on: 26 September 2010, 17:02 »
dont think you've got any option but to leave the car at home cos if the plug comes out while driving that'l be it  :sad: is it the thread on the plug or sump that breaking up?
V TEC KICKED IN Y'ALL!!!
Offline tech1889
  • Mk2 GTI FTW !!
Re: URGENT PLEASE
« Reply #4 on: 26 September 2010, 17:14 »
need to re tap the hole in sump and put a standard new bolt in there is no over option other than heli coil..
Offline houston
Re: URGENT PLEASE
« Reply #5 on: 26 September 2010, 18:07 »
most likely id say the thread is stripping off the sump, you could always drill it bigger and tap it for a larger bolt.
are the sumps aluminium? helicoils arent that good on alloy, we were using them at work on the gearboxes (notorious for the oil pipe to strip the threads on a voith gearbox) and the coils were coming loose, quite surprising especially for how tight and sealed they were in there
Offline ggggolfgti
Re: URGENT PLEASE
« Reply #6 on: 26 September 2010, 18:09 »
i would drill and tap for larger bolt if its the sump thats threaded
249 bypass, ths fr3 engine mounts, S/S decat, 2.5'' straight through exhaust, induction kit, forge split r, coilovers, 18'' alloys, much more in the pipeline
Offline oliver07
  • golf gti T 200BHP
Re: URGENT PLEASE
« Reply #7 on: 26 September 2010, 18:26 »
it looks like the end threads on the sump plug are stripped im talking about the end near the washer cleaned the plug up its going in quite tight but still got a drip
Offline oliver07
  • golf gti T 200BHP
Re: URGENT PLEASE
« Reply #8 on: 26 September 2010, 18:27 »
what size socket fits the oil filter housing
Offline houston
Re: URGENT PLEASE
« Reply #9 on: 26 September 2010, 18:53 »
have you tried fitting 2 washers like i said earlier?
