Author Topic: agu boost issues  (Read 3109 times)
jamie16v
agu boost issues
« on: 24 September 2010, 21:34 »
just reinstalled a new boost guage and i am still running the same boost as before.
r-tech remap on an agu, seems to peak at 16psi and drop to about 13-14 psi.
i have continuously checked for leaks but none to be found, i can turn the compressor pressure up to over 20psi and the air only escapes through the oil filler cap (when its removed). how do i go about checking the check valves on the servo pipe?..
this has been niggling at me for ages now as i am sure it should be holding at about 16psi.
please help as i want to make mince meat of my mates integra type R (i may just need a k03s for that but its close now)
Offline richw911
Re: agu boost issues
« Reply #1 on: 24 September 2010, 21:42 »
Faulty N75?
jamie16v
« Reply #2 on: 24 September 2010, 21:43 »
Faulty N75?
changed numerous times, it changed the characteristics but never got more than 16psi, got less with some but never more.
Offline richw911
« Reply #3 on: 24 September 2010, 21:44 »
Faulty N75?
Have you done a smoke test to check for leaks?
jamie16v
« Reply #4 on: 24 September 2010, 21:48 »
no, not sure how, have considered but the only way i can think of doing it is using the plumbers style smoke bombs and chucking one of them in the intake system and pressurising it.
is that how??  :tongue:
Offline Grand Master Patch
« Reply #5 on: 24 September 2010, 21:53 »
Am i the only one that thinks this sounds about right for a stage1 K03?
Offline richw911
« Reply #6 on: 24 September 2010, 21:56 »
R tech have one  :smiley:
http://www.myturbodiesel.com/1000q/multi/boost-leak-tester-DIY-check.htm
Offline richw911
« Reply #7 on: 24 September 2010, 22:04 »
Shouldn't it peak at 21/22 and drop to 16/17  :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 24 September 2010, 22:15 »
thats more like stage 2 k03s territory
i might expect a spike of 18 but k03 turbos are old and tired now, held boost seems about right.
jamie16v
« Reply #9 on: 24 September 2010, 22:16 »
already made one of them, dont do smoke though, lol.
