Author Topic: Blowing manifold  (Read 2535 times)
Offline Horney
Blowing manifold
« on: 25 January 2005, 08:43 »
Hi there,
I'm thinking of buying an 8v Gti off a chap who posts on here. The car in question has a blowing manifold.  How easy/expensive is this to fix? I'm talking best and worse case here. I've built a mini from scratch so tools, savvy etc are not a problem, it just all looks a bit of a nightmare behind there.
Horney
Offline Gambit
Re: Blowing manifold
« Reply #1 on: 25 January 2005, 09:25 »
a 2nd hand manifold is dirt cheap. biggest problem is rusted manifold bolts
you can drop the subframe which will allow easier access to it
also, whereabouts is it blowing? i had a crack in my old 16v manifold and a decent patch of gun-gum covered it believe it or not!!
Offline Horney
« Reply #2 on: 25 January 2005, 09:39 »
Well I spoke to my local exhaust bloke who's a good mate of mine and said that even he wouldn't do it. He said they are a total nightmare and best left to specialists to sort out.
All I'm looking for is a cheap MKII that runs and that I don't need to spend the earth on/spend hours working on straight away.
Offline Ceptor
« Reply #3 on: 25 January 2005, 09:48 »
Check out some of my prevoius posts. I had a blowing manifold on my 1.6 and solved it eventually  :grin:
GTI-BOY
« Reply #4 on: 25 January 2005, 10:04 »
I agree with Gambit but with a bit of persistance and wd40 it can be done :wink:
It's a pain in the arse though!
I removed the intake manifold (6 hex/allen key type bolts) and connections, which gave better access to the zorst manifold, then it's 6 or 8 bolts/nuts (13mm I think??) to remove from the head and 6 nuts (15mm) to disconnect from downpipe.... drown all bolts in wd40 or similiar and leave for a while...... and replace all bolts/nuts with new ones for next time! Well at least, that's how I did it :smiley:
laserblaster
« Reply #5 on: 25 January 2005, 10:06 »
i did mine! mk 2 gti 8v!
i did it on my drive first you take the inlet manifold off you need a 6mm alen key i used the smaller socket the one below the normal size one and a little exstenion bar...... to reach the allen key bolts....
once you have the inlet off you can get at the exhaust manifold with easy!! from above the engine!
you will need to jack the car up to undo the manifold to downpipe bolts!
i used the bigger normal socket to do the manifold bolts!
Offline Horney
« Reply #6 on: 25 January 2005, 12:46 »
Thanks for all your replies.
It has given me food for thought.
Horney
VeeDubGTI16v
« Reply #7 on: 25 January 2005, 15:23 »
i welded up the crack in my 1.6 manifold :evil:
Offline ...joe
« Reply #8 on: 25 January 2005, 23:28 »
its not that hard! your mate must be a lazy f**k*r!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline audiquattro
« Reply #9 on: 25 January 2005, 23:38 »
Have you done it mate?
I done it when i had the head off, its actually VERY tricky to get the inlet manifold off, there is very little access.
If i remember right, you can only get to  the middle allen key bolts with a 1/4 inch socket, so as you can imagine thats not very strong, and things can break....
So no its not an easy job at all.
