Author Topic: 16v Engine Rebuild  (Read 1417 times)
billabong
16v Engine Rebuild
« on: 23 September 2010, 22:31 »
Hi guys,
I'm going to be rebuilding a 16v engine (the head gasket is gone), along the way, what do you think I should change/upgrade and what are rough costs for these parts?
Will
Offline jonnypolish
  • t2871r needed :)
Re: 16v Engine Rebuild
« Reply #1 on: 23 September 2010, 22:44 »
Very interested in this too, Although my garage is wayyyyyyyyyy to dusty!
Rebuild + Reinforce ... then TURBO  :cool:
 MK2 VR y0!
« Reply #2 on: 24 September 2010, 00:08 »
Have the head checked and skimmed also you must use new head bolts.
If your stripping it right down, new shells (mains and bigend) and maybe rings would be a good move.
Offline Khare
  • The bear that khares
« Reply #3 on: 24 September 2010, 10:00 »
while head is out you may want to have it reconditioned. New valve guides, steam oil seals, tappets, skim and regrind the valves in. And while all that is being done, why not open her up and get it ported and polished?
Offline tinaflux
« Reply #4 on: 19 February 2011, 05:51 »
Well, there are some engine rebuild kit that are readily available online. That is where I bought mine. Though sometimes, it is best to go to your local dealer and mechanic.
« Last Edit: 19 February 2011, 06:44 by tinaflux »
Offline tshirt2k
  • Been there...Done that...
« Reply #5 on: 19 February 2011, 08:38 »
Click my sig. I did the same thing.  :wink:
Mk3 ABF 16VT Megasquirt V3
Offline javalin
« Reply #6 on: 19 February 2011, 20:37 »
nice conversion and write up tshirt2k.   :smiley:
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline tshirt2k
« Reply #7 on: 19 February 2011, 22:29 »
Cheers! :smiley: Alot of work but worth it.
