Author Topic: Dan_GTi8v, 20vt project  (Read 129171 times)
Offline Dan_GTi8v
Re: Dan_GTi8v, Future 20vt project [getting there :P]
« Reply #60 on: 21 April 2011, 01:18 »
well needless to say it isn't running yet lol
Messed about a bit with the engine bay today, wired up the alternator and finished up other bits like connecting the starter and checking all the grounds are done. Managed to get the air intake into a better position behind the battery, think I'm gonna put the coolant and water bottle on the other side, then I can run some ducting for the intake around behind the battery and hook it up to one of the lower vents
Also ordered a load of silicon hose from apmotorstore.com, a bit cheaper than siliconhoses.com and has the other bits and pieces I need like some radiator hose and vacuum piping so ordered it all from there, should be here on Friday so if I get all the bits in the drivers seat done it should be a pretty quick job once it arrives.
Fitted the throttle pedal today, I'll finish up all that lot and I'll update tomorrow with pics :)
Offline Dan_GTi8v
« Reply #61 on: 23 April 2011, 14:02 »
forgot the camera yesterday so pics will come when I'm finished today. All my piping came today so will have a look at that as well. forgot yesterday was a bank holiday  :rolleyes:
pedals are all done now just need to run the brake and clutch wires for the ecu to the brake light switch and installed a new brake light switch to the clutch pedal so it knows when its being pressed :)
Having a minor issue with the brake switch though, when I reconnected it all up to the servo the pedal seems to not travel back up as far as it did before so it doesnt quite reach the switch, which puts the brake lights on constantly as it thinks the pedal is pressed. see what happens once the brakes are bled and vacuum is back on the servo. fingers crossed :)
On the plus side though I turned it on yesterday just for a few seconds to see if it was all done right, started first time! :cool:
Offline VR6_Wherry
« Reply #62 on: 23 April 2011, 14:14 »
Great news on it starting first time  :cool: get some pics up so we can really see the progress :afro:
Offline Dan_GTi8v
« Reply #63 on: 23 April 2011, 19:04 »
some kind of tropical rainstorm going down in middlesex so pics tomorrow :)
Offline dazzawest1987
« Reply #64 on: 23 April 2011, 20:51 »
Middlesex? Whereabouts are you?
Offline Dan_GTi8v
« Reply #65 on: 23 April 2011, 20:54 »
Living in Chertsey which is technically Surrey, but the cars at my dads in Shepperton :) not far from you at all :P Drive through Ashford on my way to work depending which way I go
Offline neil1780
« Reply #66 on: 23 April 2011, 21:10 »
Well done gtting it going first time bud, and looking tidy so far. think this is the route im going down soon.:afro:
V6 4MOTION
« Reply #67 on: 23 April 2011, 21:14 »
Where do you work then?
Offline Dan_GTi8v
« Reply #68 on: 23 April 2011, 21:58 »
Cheers :) Was actually pretty amazing lol best I was hoping for was for it to not blow up!
Work at Heathrow cargo terminal for Air Canada :)
« Reply #69 on: 23 April 2011, 22:31 »
Cool sweet as,
