Author Topic: Mk3 Gti headlights tinting  (Read 2612 times)
Offline patryk92
« on: 19 September 2010, 22:08 »
Hello, Im not sure if im writing in the right section but Ive got a question..
I have a pair of mk3 gti headlights and i want to paint them inside, any advice how to unglue them ?
As i dont want to break them. Cheers Patryk
Offline Deano2711
  • 1992 VR6
Re: Mk3 Gti headlights tinting
« Reply #1 on: 19 September 2010, 22:18 »
Cut the silicone with a sharp stanley knife, then prise the glass away (very carefully use a flat head screwdriver if needed). Then remove all the old silicone with a paint scraper. When painting don't use masking tape as it pulls off the silver reflective part. Put your paint in a tub and use a small brush. Then refit the glass and silicone back up.
Offline dom
  • Back in a Mk4
« Reply #2 on: 19 September 2010, 22:20 »
If they're proper hella ones then put them in the oven for a couple of mins to soften the glue then prise them apart  :wink:
Offline patryk92
« Reply #3 on: 20 September 2010, 20:41 »
yes they're the proper hella ones, ill try to separate them first, if no luck then ill try the oven.
thank you very much for advice.
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« Reply #4 on: 20 September 2010, 20:47 »
Dont bother trying to cut the glue mate as the glass sits in a recess which you wont get a knife in.I did mine yesterday.
Gas mk3 for about 4-5 mins but to be honest i was a bit worried about melting them so kept checking them.Once the glue is soft enough just prise them apart gently and jobs a good un
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 20 September 2010, 20:54 »
Did mine with a stanley knife and it's mega easy. You only have to rub the blade around not dig in. Then the glass will pull away from the light housing. Easy job Buddy.
Offline patryk92
« Reply #6 on: 20 September 2010, 23:05 »
Ive just done it, first one was a bastard cos i didnt get it hot enough and it took me 40 minutes to split it, but the other one took me 30 seconds just pulled them apart with screwdriver. Cheers for that.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #7 on: 21 September 2010, 00:40 »
Would like my 1.8 Vento's done but I'd make a hash job of it  :nerd:
Offline rcsammy
« Reply #8 on: 21 September 2010, 00:47 »
good to know, think i might give mine a try this week
Offline jonnypolish
  • t2871r needed :)
« Reply #9 on: 22 September 2010, 10:13 »
As said before, Pop em in the over at 180degrees,
Leave for 3-5mins and the glue should be soft enough for you to pull the apart with your hands!
Then you have the fund job of scraping out the glue :( which takes forever if you do it properly!!
 MK2 VR y0!
